Old 08-12-2005, 04:08 AM   #1 (permalink)
ksp
ksp's Avatar
Date registered: Jul 2005
Vehicle: ML 430
Cat replacement. Possible???
I've got a bad blow from the left hand cat and MB are quoting over £700 for a replacement.
Anyone know if its possible to replace the whole system with stainless steel including the cats??
If it's possible, how much should I expect to pay?
ksp is offline   Reply With Quote
Old 08-12-2005, 06:17 AM   #2 (permalink)
LOCHS 2's Avatar
Date registered: Dec 2002
Vehicle: 1999 Kleemann ML43K
There are aftermarket cats in the States
that you can buy [for example from E V O sport dot com in California]which will allow more flow but it will also be louder than stock. I can't speak for Europe but I'm sure there are products there as well. Even if you go the custom route and get an entire catback set up [like I have from supersprint] it will cost you more overall than just replacing the cat at the stealer.
MODS:Kleemann Kompressor\Hardwired Valentine One\Burl/Black leather Armrestcover\Rear Burlwood Switch Cover\Burlwood/Ash Leather Shift Knob\Chrome Gear Shift Encase Set\Single Flat Burlwood Drinkholder\Burlwood/Black Leather Steering Wheel\Bose Tweeters w/ Sail Panels\Wood Trim for 3 Vents\Wood Dash Kit\Glove Box Organizer\Chrome A/C Switch Rings\Burl Frame for Instrument Panel\"nr" White Instrument Gauge Face\Chrome Gauge Cluster Rings\Passenger Floor Cargo Net\MB Stainless F&R Door Sills\MB Rubber Floor Mats\Cargo Tray with Organizers\Hella Bi-Xenons\LED front turn signals\Chrome Sport Grille\PP Chrome Front Bumper Grille\chrome head light rings\Hella xenon micro DE Foglights\Tailgate Filler Panel\Rear Spoiler w/ clear/red LED brake light\45 LED 3rd Brake light\'02 Tailights w/ LED brake lights and wired-blinking side markers\chrome taillight rings\Supersprint Muffler & Exhaust Kit w/signature Round Supersprint Tips\Chrome Tailgate Handle\AMG 18" Rims w/ DUNLOP SP 9000s\MB Blue Laurel Center Wheel Cap Emblems\Red calipers\Cell Phone Antenna\Lamella Skyview Wind Deflector\OEM Fender Flares\MB Polished Stainless Steel Step Bars\AMP Alloy Fuel Door Flap\Chrome Side Indicator Frames\Kleemann "K" and G-klasse "8" Side Emblems\Chrome Door Side Strips\Chrome Shell Inserts\chrome door handle covers\Chrome window sill covers\LED blinking side view mirror covers\12.1" Directed Video LCD OHD w/DVD.
THANKS: Cory @ Kleemann USA\Axel, Jim, & Cliff @ Knauz MB of Lake Bluff\MB of Westmont\Andrew Ling\Jerry @ ForMyMercedesdotcom\Performance Products\Park Place MB Texas\tirerack.com\MB of Naperville\JP Mercedes of Lasalle-Peru\Ben @ evosport\AMP Research\drinkholders.com\exoticwooddash.com\Rodne y\& many thanks to Pleubner...the king publisher of the ML mods from Benzworld.org
LOCHS 2 is offline   Reply With Quote
Old 08-12-2005, 10:13 AM   #3 (permalink)
pointman's Avatar
Date registered: Sep 2003
RE: Cat replacement. Possible???
cat replacement is very easy and straight forward. first check to see if yours can be repaired as alot of time cracks can be welded.
pointman is offline   Reply With Quote
Old 08-12-2005, 11:24 AM   #4 (permalink)
Vehicle: 2000 ML320
Does it just have a bad weld? If so, just remove it and have it heliarced. It is easy to remove as long as removing the torsion bar doens't scare you. There are several discussions about this. If the cat itself is bad you have no easy solutions.
warning triangle, 133,000 miles
ccweems is offline   Reply With Quote
Old 08-17-2005, 06:35 AM   #5 (permalink)
ksp
ksp's Avatar
Vehicle: ML 430
It is bad weld that should be able to be repaired.
My mechanic is going to cut and sleeve the section to make removal / fitting easier.
Old 08-17-2005, 09:12 AM   #6 (permalink)
Endurance's Avatar
Date registered: Jun 2005
Vehicle: 2000 ML320
Had the same thing done at my m class yesterday. After driving through heavy rain, some water slapshed up under the car and hit the first catalytic converter on the passenger side. When the cold water splashed on the hot cat, the weld seal that goes all around the cat cracked. Since then I had a exhaust leak and it sounded horrible.
I took it to a custom exhaust shop in town and they welded it for $60.
Daniel
Endurance is offline   Reply With Quote
Old 08-17-2005, 01:33 PM   #7 (permalink)
ksp
ksp's Avatar
Vehicle: ML 430
Just had a call from the garage, they have repaired the passenger side only to find after starting the car that the drivers side is the same!!!!!
Been quoted £250 for the whole job.
