Old 08-10-2005, 04:43 PM   #1 (permalink)
Suzy Snowflake
ThrillKill's Avatar
Date registered: Apr 2005
Vehicle: ML CLK GoPed Freightshaker & Volvo semi's, c'mawn?
Can't stand the rattle
When I had the loaner (05 ML500) one of the things I noticed is that MB, in a stroke of genius added two more screw holes for the rear license plate whereas my 99 only has two, and it sounds like she's breaking up everytime I let down the door. Does anyone know of a fix for this.....I'm not afraid to break out the drill if I have to. Thanks
-Pointless liar and inventor of the Bizzy Buzz Buzz.
Silence is Golden, Duct Tape is Silver.
ThrillKill is offline   Reply With Quote
Old 08-10-2005, 04:49 PM   #2 (permalink)
Date registered: Aug 2005
Vehicle: 01 ML 320
RE: Can't stand the rattle
I haven't put the plates on mine yet, but I've experienced this on other vehicles and solved it by putting a strip of adhesive foam behind the plate. Weather stripping material (for residential doors - get it at Home Depot/Lowes/etc) usually works well and will absorb any vibration in the plate.
_Dennis_ is offline   Reply With Quote
Old 08-10-2005, 05:43 PM   #3 (permalink)
Suzy Snowflake
ThrillKill's Avatar
_Dennis_ - 8/10/2005 5:49 PM
Why didn't I think of that? Thanks Dennis and Welcome.
Old 08-10-2005, 05:46 PM   #4 (permalink)
Vehicle: ML500, E320 4Matic
You can also use a frame for the plate. This stops the flexing and resultant noise.
sosh is offline   Reply With Quote
Old 08-10-2005, 05:59 PM   #5 (permalink)
Suzy Snowflake
ThrillKill's Avatar
sosh - 8/10/2005 6:46 PM
I have a stainless steel one on there now which accounts for the majority of the clatter [:(!]
Old 08-10-2005, 06:05 PM   #6 (permalink)
Vehicle: 2002 ML55K
Send a message via AIM to jdbower Send a message via MSN to jdbower
ThrillKill - 8/10/2005 7:59 PM
Install a nice subwoofer in the back and enjoy the extra boost the license plate gives you? I pulled up next to a Civic once and my buddy was wondering what the mysterious buzzing was...[:)]
Thanks,
Jeff
<hr><small>2002 ML55 (debadged), <A HREF="http://www.benzworld.org/forums/forums/thread-view.asp?tid=46299&posts=20" target="_blank">Metallic Black Rear Star</A>, 2003 DVD Navigation, fire extinguisher, OEM trailer hitch, OEM Smoke Hood Deflector, OEM Smoke Sunroof Deflector, OEM basic carrier, v60, VES, CD Changer, <A HREF="http://www.*************.com/contsp/product.asp?intProdID=D-ML163-LED-Painted&model=W163&category=LED+Brake+Lights+" target="_blank">LED rear wing</A>, <A HREF="http://www.*************.com/mb_results_m.asp?model=W163&class=m-class&category=LED+Replacement+Bulbs" target="_blank">LED brakes and rear turn signals</A>, <A HREF="https://www.designtech-intl.com/merchant.ihtml?pid=47&lastcatid=12&step=4" target="_blank">DesignTech halogen backup bulbs</A>, <A HREF="http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&category%5Fname=CT LG%5F010%5F012%5F011%5F000&product%5Fid=276%2D272" target="_blank">amber ambiant passenger footwell lighting</A>, <A HREF="http://www.valentineone.com/home.asp" target="_blank">Valentine V1</A>, <A HREF="http://www.ssiamerica.com/products/neo35/index.shtml" target="_blank">Neo Car MP3 player</A>, <A HREF="http://www.tirerack.com/accessories/smartire/smartire2.jsp" target="_blank">SmarTire wireless tire pressure monitoring</A>, ML430 winter rims with Dunlop WS M2 tires (255/60R17), <A HREF="http://www.benzworld.org/forums/forums/thread-view.asp?tid=45318&posts=20" target="_blank">crossdrilled/slotted/frozen/nickel plated rotors</A>, <A HREF="http://www.benzworld.org/forums/forums/thread-view.asp?tid=61783&posts=20">Autobahn mirror, rear fresnel lens</A>, <A HREF="http://www.benzworld.org/forums/forums/thread-view.asp?tid=69466&posts=20">SnowBear Utility Trailer</A>, <A HREF="http://www.escortradar.com/gtimer.htm">Escort GTimer GT2</A>, silver/polished <a href="http://www.hrewheels.com">HRE</a> <a href="http://images2.hrewheels.com/wheels/images/enlarge/enlarge-645r.jpg">645R</A> 20x9.5 <A href="http://www.wheelboutique.com">rims</A> with matching 295/40ZR20 <A HREF="http://www.tirerack.com/tires/tires.jsp?tireMake=Dunlop&tireModel=SP+Sport+9000& partnum=94ZR09000">Dunlop SP9000s</A>, <A HREF="http://www.kleemann.dk/tuning/index.htm">Kleemann Supercharger and ECU upgrade (550HP and 502 ft-lbs!)</A>. </small><center><HR>BMW is "Wanted, Mercedes Benz" backwards.<br><a href="http://www.benzworld.org/forums/view-profile.asp?action=view&uid=1044">tcp_ML500</a> says: Jeff's ML55K blows but BenzWorld doesn't!</center>
jdbower is offline   Reply With Quote
Old 08-11-2005, 06:45 AM   #7 (permalink)
Date registered: May 2005
Vehicle: 2001 ML 320
My 01' 320 has 4 holes...still rattled a tad bit so I used some rubber washers under the screw heads - worked like a charm!
treeman5 is offline   Reply With Quote
Old 08-11-2005, 10:28 AM   #8 (permalink)
RAN
RAN's Avatar
Hey Treeman, I have the same 4 bolt set-up on my '01 ML 320. The dealer added their faceplate and rubber washers. They also adjusted the tailgate. That took care of the rattle and rumble.
RAN[:)]
RAN is offline   Reply With Quote
