» Site Navigation » Other Sites
» Network Links
07-22-2005, 09:05 PM
#1 (permalink )
Date registered: Sep 2003
Vehicle: 2001 ML320
need help removing the headliner
hi people. i need help on how to remove the headliner. the hinge of the passenger side sunvisor, the side where you can detach/attach the sunvisor broke. the half part of the plastic is inbetween the headliner and the roof itself. can anybody suggest on how to remove the other half? all i can think of is remove the headliner thru the sunroof. can i remove the modlings safely around the sunroof that holds the liner so that i can insert my hands inbetween an hopefully i can get the broken hinge? any tips on how to remove the modlings or the headliner? thank you.
ryan
Mods: POLISH STEP BARS, ALUMINUM BILLET FUEL DOOR, TOW HITCH, A/C CHROME RINGS, CHROME HANDLE CUPS, REAR SPOILER
07-22-2005, 09:31 PM
#2 (permalink )
Vehicle: 2001 ML320
RE: need help removing the headliner
or maybe remove the light assembly that are close to the rearview mirror. and hoping there is bigger hole that i can access so to remove the broken clip.
07-22-2005, 11:26 PM
#3 (permalink )
Date registered: Jul 2005
Vehicle: 99 ML430, 90 300E,
Would love to help, can you tell us what year and model you are working on? There are already a lot of pics and advice about the headliner removal here and we can hopefully give you a lot of help.
07-23-2005, 12:36 AM
#4 (permalink )
Vehicle: 2001 ML320
noodles,
my truck is 2001 ML320. pls let me know how can i get the other half of the hinge inbetween the headliner and the roof. thanks in advance.
ryan
07-23-2005, 01:36 PM
#5 (permalink )
I have been searching for the thread that had pics of each step of the removal and can't locate it yet. I am still looking. Maybe someone else remembers it. I saw it a couple years ago before I regged here and just a few weeks when researching installing the VES in the vehicle.
07-25-2005, 07:19 AM
#6 (permalink )
Date registered: May 2005
Vehicle: Brabus ML 270CDI
I think you mean paul's OEM VES Install right? He made a website with WIS pdf's .... but nothing with the headliner removal...
http://home.earthlink.net/~phdwebsite/ves.htm
here is the sun visor removal.
07-25-2005, 10:59 AM
#7 (permalink )
Thanks for digging that up. I thought I was losing more of my mind.
07-26-2005, 12:40 AM
#8 (permalink )
Here you go!
07-26-2005, 01:21 AM
#9 (permalink )
Headliner Removal Supporting Doc
... because the the headliner is underneath everything mounted on it, as well as the side mouldings, you have to remove these first!.
It get even worse.... The side mouldings (b/c column) are underneath the bottom mouldings, so you have to remove these prior as well......
The supporting doc to remove parts prior to the headliner are as follows.
... Consider this a lower->middle->upper panel/moulding WIS removal post!!!! ... then remove the headliner!!!!
PS: USE THIS POST FOR ANY FUTURE! ... HOW DO I REMOVE Q's
Attached Images 29_1544007_726200532248AM.JPG (37.3 KB, 57 views) 29_1544007_726200532305AM.JPG (22.6 KB, 44 views) 29_1544007_726200532331AM.JPG (31.5 KB, 41 views) 29_1544007_726200532342AM.JPG (15.1 KB, 41 views) 29_1544007_726200532411AM.JPG (42.9 KB, 39 views) 29_1544007_726200532439AM.JPG (43.4 KB, 34 views) 29_1544007_726200532508AM.JPG (38.7 KB, 36 views) 29_1544007_726200532529AM.JPG (27.5 KB, 34 views) 29_1544007_726200532557AM.JPG (33.1 KB, 32 views) 29_1544007_726200532627AM.JPG (25.7 KB, 33 views) 29_1544007_726200532648AM.JPG (21.4 KB, 31 views) 29_1544007_726200532720AM.JPG (36.2 KB, 31 views) 29_1544007_726200532740AM.JPG (29.7 KB, 30 views) 29_1544007_726200532818AM.JPG (51.8 KB, 30 views) 29_1544007_726200532835AM.JPG (24.0 KB, 29 views) 29_1544007_726200532912AM.JPG (42.7 KB, 29 views) 29_1544007_726200532937AM.JPG (30.6 KB, 29 views) 29_1544007_726200533012AM.JPG (52.5 KB, 29 views) 29_1544007_726200533035AM.JPG (40.4 KB, 28 views) 29_1544007_726200533105AM.JPG (44.7 KB, 30 views) 29_1544007_726200533127AM.JPG (31.9 KB, 28 views) 29_1544007_726200533151AM.JPG (31.5 KB, 30 views) 29_1544007_726200533217AM.JPG (42.4 KB, 28 views) 29_1544007_726200533249AM.JPG (43.1 KB, 31 views) 29_1544007_726200533315AM.JPG (42.4 KB, 27 views) 29_1544007_726200533334AM.JPG (26.9 KB, 28 views) 29_1544007_726200533402AM.JPG (32.0 KB, 24 views) 29_1544007_726200533430AM.JPG (32.2 KB, 24 views) 29_1544007_726200533450AM.JPG (22.0 KB, 26 views) 29_1544007_726200533504AM.JPG (17.9 KB, 26 views) 29_1544007_726200533530AM.JPG (32.7 KB, 30 views) 29_1544007_726200533555AM.JPG (42.2 KB, 29 views)
10-27-2005, 08:59 AM
#10 (permalink )
Vehicle: 99 ML 320, 05 FX35, 02 745Li
How do I get the documents posted here?
Thread Tools Display Modes Linear Mode
