» Site Navigation
» Other Sites
Old 07-12-2005, 05:12 AM   #1 (permalink)
Date registered: Jul 2004
Vehicle: 1999 ML 320
Dash noises upon road impacts
Okay,
Been having a problem with the "wood" surround around the radio...it is coming loose and appears to have been glued on previously. Radio is therefore loose and makes a lot of noise upon minor to moderate impacts on road while driving.
Also, the entire dash seems to make noise as if everything is loose inside. Anyone else had the same problems and any recommendations?
Thanks in advance!!!
Kindest regards,[:)][:0]
Dave Lackey
1999 ML320 (BLACK OPAL)
dave lackey is offline   Reply With Quote
Old 07-12-2005, 06:47 AM   #2 (permalink)
redeye's Avatar
Date registered: May 2004
RE: Dash noises upon road impacts
Felt is your best friend.
redeye is offline   Reply With Quote
Old 07-12-2005, 08:19 AM   #3 (permalink)
rudeney's Avatar
Date registered: Dec 2004
Vehicle: 2001 ML320
This sounds like more than loose trim. The wood panel is held on with several metal trim clips and it is generally a fairly secure fit. The radio slides into a double-DIN slot and is held in place by spring-loaded “ears� on either side. These “ears� are released when a special tool is inserted into the slots on the face of the radio. The face of the radio sits against a flange on the wood trim panel, so the wood panel could only be loose if the radio were also loose. Since you say that both the wood panel and the radio are loose, my guess is that the support they attach to behind the dash are either broken or have come detached. I can’t immediately recall how they are assembled, but I believe these support are plastic and are screwed into the metal dash supports. I’d remove the radio and wood trim to investigate further.
- RODNEY
rudeney is offline   Reply With Quote
