2000 ML430 Fuel Filter Upgrade
I am in the process of installing the updated fuel filter in 2000 ML430. I am to the point where I have removed the end cap beneath the rear seat and I can see the fuel lines. I had to remove the 60% bench to get at this since the carpet is rather stiff. The WIS system does not state to remove the seat but I do not see how it can be done otherwise.
I plan on removing the fuel lines from the filter before removing from the pump. Besides opening the gas gap, is there anything else I need to do to avoid getting doused with fuel?
Part of the procedure involves starting the vehicle before sealing the end cap to check for leaks. I am concerned about starting vehicle without the rear bench installed; there is a connector for the seat belts (I think) that is obviously disconnected at the moment. There is a warning in WIS to remove the connector with the ignition in “0� to avoid an SRS error. However, nothing else is stated like starting vehicle with it not connected. Does anyone have feedback on this?
Also, I was considering testing the fuel pressure before and after the filter change but I really do not know how or have a gauge at the moment. Can someone give specifics about this procedure? Do you think this is worth it?
Thanks.
