» Site Navigation
» Other Sites
Old 07-10-2005, 09:50 PM   #1 (permalink)
RusML270
Date registered: Jul 2005
Vehicle: ML270
Oil Filter tool for ML270
Hi everyone
Been reading many of the posts with interest and have a couple of quick questions regarding changing the engine oil in a ML270
What is the diameter of the oil filter wrench used to remove the plastic filter cover, is it 76mm with 14 segments.
Also can the oil be drained via the drain plug at the bottom of the sump, reason I ask is all information regarding changing the oil is via the vaccum pump out unit(toploader??)
Thanks
Russ
RusML270 is offline   Reply With Quote
Old 07-11-2005, 04:08 AM   #2 (permalink)
marcelc
RE: Oil Filter tool for ML270
RusML270 - 7/11/2005 5:50 AM
What is the diameter of the oil filter wrench used to remove the plastic filter cover, is it 76mm width 14 segments.
Thanks
Russ
Yes and yes, however draining the oil via the drain plug is messy.
I have always drained the oil from all my cars via the sump drain plug, but, when I looked underneath the ML 270 I decided to invest in a topsider.
I am happy that the Topsider method removes all the oil as the new oil would soon mix with any of the old black oil and show a change in colour which does not happen.
marcelc is offline   Reply With Quote
Old 07-12-2005, 12:20 AM   #3 (permalink)
alphonsohall
alphonsohall's Avatar
Date registered: Nov 2004
Vehicle: ML 270CDI 2002
The oil filter removal tool for a BMW K1200 motorcycle is the same one that you need for the ML270 (Diesel)
If you have a BMW dealership nearby then pick up the tool from them , cheaper too!
alphonsohall is offline   Reply With Quote
Old 07-12-2005, 02:26 AM   #4 (permalink)
pleubner
pleubner's Avatar
Date registered: May 2005
Vehicle: Brabus ML 270CDI
If you really want to do the bottom!
If you enjoy getting underneath your ML, you could opt for the device made by FRAM called the SureDrain.
The SureDrain competing product is the Fumoto valve.
http://www.fumotovalve.com/
I have no personal experience with this product so I am not speaking from personal experience. They make what they call an "N-type" valve which has a nipple that you can attach a plastic tube to so you can direct the oil where you want; granted that there is enough space
Looked it up and the fumoto valve requires an adapter for the ML.
http://www.fumotovalve.com/merchant.cfm?pid=464&step=4
pleubner is offline   Reply With Quote
Old 07-12-2005, 05:35 AM   #5 (permalink)
treeman5
Vehicle: 2001 ML 320
I drain the oil from underneath on my 01' 320 with no problems...I usually jack up the driver's side of the car and only get a slight dribble on the stabilizer bar near the end of draining. I thought about getting a topsider but decided to try draining the first time to see how it went.
treeman5 is offline   Reply With Quote
Old 07-12-2005, 08:33 AM   #6 (permalink)
rudeney
rudeney's Avatar
Date registered: Dec 2004
Vehicle: 2001 ML320
Once you go from the top, you’ll never climb underneath again! I bet that within 30 minutes, I could change the oil in an ML wearing a full suit and tie and not get dirty at all using a topside vacuum. It’s just so easy. People may complain about MBZ, but they definitely design their vehicles for easy maintenance. Having the oil filter right on top of the engine and a service position to hold the hood completely vertical makes tasks like oil changes so much easier.
- RODNEY
rudeney is offline   Reply With Quote
Old 07-12-2005, 10:24 AM   #7 (permalink)
treeman5
Maybe one day I'll buy a topsider but I usually crawl the distance under my truck anyway when changing the oil to check for anything that "doesn't look right". My next house I build (hopefully in the next year or so) I'm going to have a 2 story garage so I can buy one of the $3000 hydraulic lifts. Then I'll be happy! [:D]
