Old 07-10-2005, 12:20 AM   #1 (permalink)
Date registered: Aug 2004
Vehicle: '99 ML320
Blinking "LOW RANGE" at startup on BOTH of my ML's
hi there.. i thought i'd get on here to use the search function instead of probably reposting... but search is down i guess.
i have '99 ML320 and a '03 ML350 (i love my MLs :)) but lately they have both been acting up! the "Low range" warning lights blink about 4 times right after i turn them on. the '03 has had that problem checked and supposedly fixed before the warranty finished, but it came back about a month after the final checkup. and the 99 just started having this problem. neither of them actually go into low range when the light blinks.
its EVERY time i start them up. only once did the 99 actually start up in low range when the lights blinked, i had to restart the car. any ideas wtf?
Express is offline   Reply With Quote
Old 07-10-2005, 04:06 AM   #2 (permalink)
bayles999's Avatar
Date registered: Jun 2004
Vehicle: ML 320 + M330ci Conv
RE: Blinking "LOW RANGE" at startup on BOTH of my ML's
Hi express,
I had this problem in my 2002 ML320 about 8 months ago, according to the manual when the low range light blinks at startup there is something wrong with the low range transfer case, i took ours to the local dealer and the problem has not returned since.
bayles999
2002 ML 320 Luxury (Tanzanite Blue with Java Interior)
2005 BMW M330ci Conv. (Sparkling Graphite with Platnium Interior)
bayles999 is offline   Reply With Quote
Old 07-11-2005, 06:06 AM   #3 (permalink)
00 ML430 Bulldog's Avatar
Date registered: Mar 2003
Vehicle: 2000 ML430
Express - 7/10/2005 2:20 AM
You need to put the truck in low range and take of low range, turn off the truck, then restart it. This usually fix that problem. If it does not atrip to the dealer is in order.
ONE TUFF LOOKING ML!!!
00 ML430 Bulldog is offline   Reply With Quote
Old 07-12-2005, 10:13 AM   #4 (permalink)
Vehicle: '99 ML320
i did that the other day to see if low range still worked.. have to check if hte light still blinks... thx
Old 07-12-2005, 11:27 AM   #5 (permalink)
Date registered: May 2005
Vehicle: 2001 ML 320
If I put it in low range and drive and then shut off the car, when I start it back up, the low range light flashes as well but then stays on because it's still in low range. I noticed if you push the low range switch to switch it off and you're not in neutral, it will also flash. Perhaps your switch is stuck in the "off" position and that's why it flashes everytime you start it up?
treeman5 is offline   Reply With Quote
Old 07-13-2005, 02:09 AM   #6 (permalink)
Vehicle: '99 ML320
i did what bulldog suggested, and it worked like a charm. thanks[:D]
Old 11-18-2006, 09:18 PM   #7 (permalink)
AC_ML's Avatar
Vehicle: Black 2005 ML 500
I am having the same problem with my 2005 ML 500. I'll check to see if Bulldog's recommendation works.. Thanks..
AC
2005 ML 500
Black, 18" AMG Wheels, 285/60R18 Falken Ziex ST/Z + Bi-Xenons(+ Drew's e-code mod), Yakima roof bars. Former vehicle 2001 ML 320 with 108K miles, when traded, and a large repair/defect history. After 3 years of owning my current 2005 ML 500, it has become another unreiliable vehicle with a very large/expensive repair/defect history..
AC_ML is offline   Reply With Quote
Old 11-18-2006, 10:10 PM   #8 (permalink)
Date registered: May 2004
Vehicle: 2000 ML320
The blinking light indicates that the low range selector motor on the transfer case did not cycle properly at some point. You can try engaging/disengaging low range; i think the blinking light will go out once the transfer case goes through the cycle. My sister's '02 ML is doing the same thing
NOTE: Since your LR light is blinking, I would be careful here. There is a risk that the transfer case could get stuck in LR (it happened to me). If this happens, you will probably need a flatbed unless your shop is very close by. If you don't ever use LR, you might consider getting used to the blinking light.
I paid about $350 to replace the selector motor. I believe there is an updated part. The motor is clearly visible from underneath the car. Should be a 10 min DIY. You should consider changing the xfer case fluid while you're at it.
Magweed is offline   Reply With Quote
Old 11-18-2006, 10:13 PM   #9 (permalink)
Vehicle: 2000 ML320
Some on the forum recommend exercising the LR selector motor every now and then.
Old 11-18-2006, 11:37 PM   #10 (permalink)
soulsociety714's Avatar
Date registered: Jan 2006
Vehicle: ml320 2002
Send a message via AIM to soulsociety714
you need to replace the transfer case which is about $400 at an independent shop.
soulsociety714 is offline   Reply With Quote
