» Site Navigation
» Other Sites
Old 07-08-2005, 08:56 AM   #1 (permalink)
vsNYC
vsNYC's Avatar
Date registered: Feb 2003
Vehicle: 2001 ML55 ///AMG
Send a message via AIM to vsNYC Send a message via Yahoo to vsNYC
Aftermarket Window Switches ..... Are they available?
I was wondering if you can swap your regular switches for the ones that let you close the window with one touch of a button? (i.e. you can press the window button once and it will open by itself, but you can't pull it up and have the window close by itself)
Thanks
vsNYC is offline   Reply With Quote
Old 07-08-2005, 09:47 AM   #2 (permalink)
treeman5
Date registered: May 2005
Vehicle: 2001 ML 320
RE: Aftermarket Window Switches ..... Are they available?
That's not a function of the switch...it's programmed into "the brain".
treeman5 is offline   Reply With Quote
Old 07-08-2005, 10:12 AM   #3 (permalink)
vsNYC
vsNYC's Avatar
I think it has to do with the switch because when you click the button to roll down the windows you can feel an extra click.
The click is not there when you try to roll them up.
Old 07-08-2005, 12:29 PM   #4 (permalink)
rudeney
rudeney's Avatar
Date registered: Dec 2004
Vehicle: 2001 ML320
The one-touch up and down function of the MY 2002+ ML’s is built into the switch assembly. While it might be possible to retrofit the 2002 windows switches into a MY 1998-2001, it would likely be too costly and very troublesome. My recommendation would be to look at something like the autoloc one touch kits:
http://www.topendmotorsports.com/exterior/windows/autoloc/
- RODNEY
rudeney is offline   Reply With Quote
Old 07-08-2005, 03:40 PM   #5 (permalink)
Benza
Benza's Avatar
Date registered: Nov 2002
Vehicle: 2004 HUMMER H2 -- 98' ML 320 (Sold)
I used the autoloc (as mentioned above) for the sunroof in my H2 and it works great! It looks like you could use this on any window but it could get a little pricey as you would need 1 per window.
http://www.autoloc.com/detail.lasso?itemid=WC1000
Benza is offline   Reply With Quote
Old 07-08-2005, 04:34 PM   #6 (permalink)
bigcatny
Vehicle: 98ML320
Does anyone know how the pinch protection works. Is that also programmed into the switch or computer or is there an additional sensor? Just curious as that might complicate a retrofit also.
bigcatny is offline   Reply With Quote
Old 07-08-2005, 05:17 PM   #7 (permalink)
dahappybanana
dahappybanana's Avatar
Date registered: Jun 2005
Vehicle: 1990 300E, 2002 ML500
Send a message via ICQ to dahappybanana Send a message via AIM to dahappybanana
by pinch protection do you mean when the window is going express up by itself from the double hit of the button and it feels pressure it stops and backs an inch? The ML500 has that, I believe it to be in the window assembly, not the switch
dahappybanana is offline   Reply With Quote
Old 07-09-2005, 08:23 AM   #8 (permalink)
redeye
redeye's Avatar
Date registered: May 2004
bigcatny - 7/8/2005 5:34 PM
We had this same debate a while ago on this board. The Autoloc retrofit is supposed to have that built into the unit, but it means that it must be installed where the full load from the window motor is available to it. It should be fairly simple to do an install of 1 Autoloc unit into the center console at the window switches, keeping the standard 1-touch down function and having the single Autoloc unit providing 1-touch up for both front windows. The unknown in that theory is whether the full window load is available at the window switches or only some instrument current...
redeye is offline   Reply With Quote
Old 07-10-2005, 02:26 PM   #9 (permalink)
onesixthree
Date registered: Sep 2003
Vehicle: '02ML320
I'd like to try this for the sunroof.
onesixthree is offline   Reply With Quote
Old 07-11-2005, 10:31 AM   #10 (permalink)
rudeney
rudeney's Avatar
Vehicle: 2001 ML320
Pinch protection for both the factory system in MY2002+ ML’s and the Autoloc aftermarket add-on is implemented by sensing the current draw on the window motor. My understanding is that the window switches in the console for pre-2002 ML’s do carry the full current load of the window motors. The Autoloc retrofit should be an easy upgrade with all wiring performed in the console.
- RODNEY
