Old 06-17-2005, 12:47 PM   #1 (permalink)
BenzWorld W211 Host
stroessel's Avatar
Date registered: Jan 2004
Vehicle: E270 CDI -03
Send a message via ICQ to stroessel
Transmission trouble
oh what a great day this was. sun was shining and we (mah girl and I) were about to visit some friends in their summercottage.
I had just refueled my seadoo waterjet and was about to leave the gasstation, I put it in DRIVE and the whole car bounces unusually hard forward.
Oh well...I drive off...
suddenly the transmission wont change gears. it runs on the same gear and I cannot change it manually. it's stuck.
I stop the car. turn it off. waits one-two minutes. starts it up again. same thing when I put it in Drive.
I phone my local mechanic-friend and he tells me to stop somewhere and try to reset the "computer" by removing the +-connection from the battery and leave it off for about 15-20 minutes.
so I do so.
after 20min...same thing. but this time the "BAS ESP" warning light comes on and goes off after about 2-3 minutes.
so my fellow ML-owners...what kind of trouble am I in? [:(][:(]
http://www.marcusmarcus.se
1998 C180 Classic (sold)
2001 ML270 CDI (sold)
2003 E270 CDI Avantgarde (sold)
2006 W203 220K (sold)
stroessel is offline   Reply With Quote
Old 06-17-2005, 12:58 PM   #2 (permalink)
Vehicle: 98ML320
RE: Transmission trouble
sounds like your locked in 2nd gear "limp home mode."
This happened to me and it turned out that wiring in my engine got chewed on by something and was shorting out the computer. I had to change out wiring harness in the engine which was not cheap or quick. My symptoms were similar. Drove somewhere, shut off car for a few minutes, restarted then bam... won't shift out of 2nd. Had to drive home then to the dealer like that the next day.
Can't suggest anything for you except to hope it's something much simpler. Sorry for your bad fortune. Good luck.
Perhaps Roadside assistance?
bigcatny is offline   Reply With Quote
Old 06-17-2005, 02:48 PM   #3 (permalink)
roadsession's Avatar
Date registered: Nov 2002
Vehicle: 99 ML320 C230 530xi
stroessel - 6/17/2005 2:47 PM
so I do so.
BAS ESP light is because you have to reset steering sensor by turning wheel all the way to the left and to the right.
anytime you disconnect and reconnect power, that's what you have to do.
The tranny problem could be a transmission control module. Hook up to dealer computer and they will read fault codes.
BMW E60 530xi
MB W163 ML320
MB W202 C230
roadsession is offline   Reply With Quote
Old 06-26-2005, 12:48 AM   #4 (permalink)
BenzWorld W211 Host
stroessel's Avatar
Problem solved.
I don't know what the part is called in english but if I translate from swedish it should be called "RPM-sensor".
They replaced it and changed my transmission-oil at the same time.
Runs like a dream again! [:D]
Total cost (with todays exchange rate): $380
Old 06-26-2005, 01:05 AM   #5 (permalink)
Demon_possessed's Avatar
Date registered: Apr 2005
Its cheap their do you think it could have been the skedoo you were pulling
Demon_possessed is offline   Reply With Quote
Old 06-27-2005, 10:19 AM   #6 (permalink)
AC_ML's Avatar
Vehicle: Black 2005 ML 500
Congratulations.. It's great that it was not the transmission..!!!
Do you have the MB part number..? From your dealer receipt/invoice..? It will be handy to know..
Thanks,
AC
2005 ML 500
Black, 18" AMG Wheels, 285/60R18 Falken Ziex ST/Z + Bi-Xenons(+ Drew's e-code mod), Yakima roof bars. Former vehicle 2001 ML 320 with 108K miles, when traded, and a large repair/defect history. After 3 years of owning my current 2005 ML 500, it has become another unreiliable vehicle with a very large/expensive repair/defect history..
AC_ML is offline   Reply With Quote
