sluggish acceleration 2001 ML320 - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 06-16-2005, 01:17 PM Thread Starter
gzt
gzt's Avatar
Date registered: Jun 2005
Vehicle: ML320, S430
about 50k miles, ran perfectly for a long time. Suddenly started to have some problems: rough idle, sluggish acceleration and finally one cylinder cut off.
At the same time I replaced the fuel filter (pump was making some high pitch noise) than replaced a coil and all spark plugs, plus two spark plug wires.
Engine runs so-so, but still far from the perfect run.
Any idea what else to do?
The garage mechanics are telling me that everything is OK, but I know the vehicle is far from beeing perfect :)
gzt is offline
post #2 of 11 (permalink) Old 06-16-2005, 02:38 PM
RE: sluggish acceleration 2001 ML320
There may be some inlet manifold switching flaps, I do not know about the 320, but the newer 350 motor has 'tumble flaps' for each cylinder and an EGR flap either for each cylinder or for each bank. If any of these valves stick open, closed or partially open the performance will be obviously bad.
You could try gas additive which frees stuck valves or dirty injectors - maybe other reader will chime in with their experiences.
This is at least a cheap and simple alternative.
marcelc is offline
post #3 of 11 (permalink) Old 06-17-2005, 09:51 AM
rudeney's Avatar
Date registered: Dec 2004
Vehicle: CURRENT: 2011 SL550, 2002 C240 FORMER: 2007 CLK550 Cabriolet, 2001 ML320, 1984 300TD
Quoted: 528 Post(s)
The 112 engine also has the manifold "flaps". They are used to create a variable intake length so that the torque curve can be manipulated for better performance. It’s doubtful that any malfunction of these flaps could cause much of a problem in only one cylinder.
- RODNEY
rudeney is offline
post #4 of 11 (permalink) Old 06-18-2005, 01:28 PM Thread Starter
gzt
gzt's Avatar
Thank you for sharing your experience on this subject.
I just have more lights into it.
Got the car from mechanic last night. They replaced ALL the high voltage wires and cleaned injectors.
While talking to the mechanic, he said the missfire was reported on diferent cylinders, not just same one over.
I did mentioned they replaced a fuel filter - it was a new type filter - with the whole upgrade kit - and this filter caused a fuel pressure drop by 5 psi. So switching back to the old type filter helped with the better fuel delivery.
While getting on a highway I got Engine Check light ON again. THis time I was at the time when mechanic was checking the faulty codes. The code was missfire on cylinder 2 and possible TWC damage.
any idea to help solving this puzzle ?
gzt is offline
post #5 of 11 (permalink) Old 06-19-2005, 08:07 AM
Date registered: Aug 2004
Vehicle: 98 ML320
Quoted: 6 Post(s)
<<While getting on a highway I got Engine Check light ON again. THis time I was at the time when mechanic was checking the faulty codes. The code was missfire on cylinder 2 and possible TWC damage.
any idea to help solving this puzzle ?>>
A failing Mass air flow meter will cause random misfire codes to be set. This is a very common failure and does affect driveability. Sometimes acceleration is normal, sometimes very flat!
Regards,
jim in Phoenix
Jim Friesen
Phoenix, AZ
98 ML320
79 300SD
jfreezn is offline
post #6 of 11 (permalink) Old 06-19-2005, 08:36 AM
00 ML430 Bulldog's Avatar
Date registered: Mar 2003
Vehicle: 2000 ML430
Try a new Mass Airflow Meter. A defective unit will cause all the problems you describe.
ONE TUFF LOOKING ML!!!
00 ML430 Bulldog is offline
post #7 of 11 (permalink) Old 06-19-2005, 05:45 PM
roadsession's Avatar
Date registered: Nov 2002
Vehicle: 99ML320 (retired) C230 530xi 911-C4
gzt - 6/16/2005 3:17 PM
Use OBDII scanner to check for faults. do you have a check engine light on?
if not, then it maybe during the coil pack / wire install that they messed it up big time and now you have missfires.
Porsche Carrera 4 Cabriolet
BMW 530xi
MB W202 C230
MB W163 ML320 (SOLD)
roadsession is offline
post #8 of 11 (permalink) Old 06-19-2005, 10:26 PM
J-bird's Avatar
Date registered: Oct 2003
Vehicle: 2000 ML320 & 1997 Boxster
Did they check ALL the spark plug wires?
I had a fouled (wet) spark plug wire and it fixed my misfires. Random misfires first they told me it was water in the fuel rail had to take it back 3 times....
MY00 ML320
75Kmiles / Black Opal / M1 Package
Sunroof / Heated Seats / CD Changer
Mods: Front Plate delete / Badge delete /35% tint front windows / OEM Trailer Hitch / OEM Step Bars
MY97 Porsche Boxster
56Kmiles / Ocean Blue / Sport Package / Hard Top
Mods: B & M Short Shifter / MY00 Shift knob & boot / SS intake grills / Badge delete / front plate delete
Track/AutoX Shoes: Kumho Victoracers
Street Shoes: Kumho Ecsta 712's
J-bird is offline
post #9 of 11 (permalink) Old 06-27-2005, 07:37 PM Thread Starter
gzt
gzt's Avatar
I would like to thank you all who responded to my problem. It has been more than a Week passed since I replaced the Air Flow Meter and ALL problems dissapeared.
I am glad I posted this problem here on the forum.
I was going nutts trying to figure out what might be wrong.
Lets summarize:
1) it started with whisseling fuel filter
- replaced an original fuel filter with the upgraded one (the whole kit)
2) sluggish acceleration - fuel pressure reduced by 5 psi
3) missfire code on various cylinders
4) disconnected single cylinder (2 and later 5)
- replaced all the spark plugs, high voltage wires
- replaced the fuel filter to the old style - (pressure back to normal)
5) missfire still existed, and error code showed again faults on various cylinders with error code on demaging TWC
- replaced Air Flow Meter
NO MORE MISSFIRES ERRORS
I am glad I did not listen to the mechanic who suggested to replace TWC ($3k brrrrr)
thanks again :)
gzt is offline
post #10 of 11 (permalink) Old 06-28-2005, 09:55 AM
Date registered: Sep 2004
Vehicle: 2000 ML320
What was the OBD II code, did you ever get P0173?
Thanks
Senz
senz is offline
