Old 06-07-2005, 11:42 AM   #1 (permalink)
ranjitsml320's Avatar
Date registered: Jul 2004
ML320 Front Shocks, and ML350 Front Shocks
Hi
My 2001 (Facelift) ML320 driver side front shock needs replacing as it is leaking everywhere! I have sourced ML350 Shocks from a 2003 ML which was fire damaged. Will these fit my 320 and is it adviseable to use old shocks they are £125, approx $225 US. Can i have you opinions guys. I want to replace the leaking shock soon, can anyone recommend any other makes of shocks or are Merc Shocks the best?
Thanks
ranjitsml320 is offline   Reply With Quote
Old 06-07-2005, 12:56 PM   #2 (permalink)
Date registered: Sep 2003
Vehicle: '02ML320
RE: ML320 Front Shocks, and ML350 Front Shocks
you can buy brand new bilstein shocks for that price. oem shocks will blow out again sooner or later.
onesixthree is offline   Reply With Quote
Old 06-07-2005, 06:34 PM   #3 (permalink)
gwwaterman's Avatar
Date registered: Oct 2004
Vehicle: 2001 ML 430 Sport
I just installed a set of Bilsteins on the 430 and I expect the proceedure would be extremely similar for the 320. A pair of shocks purchased together was only $200 on-line and took fairly little time to install.
Remove the top nut first. The bottom connection is a large bolt and the top is a nut on a threaded rod. With the car on jack-stands, I put another stand just below one of the wheel spindles. (wheels are off). The suspension weight is taken up inside the shock so this stops the OEM shock top threaded shaft from turning as you loosen the nut. It is deep in the engine area and not really accessable from below. A deep socket on a long extension allows you to loosen the top shock nut from atop the engine compartment very easily. When the nut comes off, the front wheel spindle (suspension) will fall to the waiting jackstand, hopefully - not too far - mine hardly moved as I had it set correctly, but the nut pops off under the pressure - but your gonna throw the shock out anyway.
Put the bottom bolt in first. A lot of torque is required to free the OEM bottom bolt as it is very large and it is important that this one not come out over time, so replacement should involve significant foot pound installation pressure (torque).
The Bilstein shock has a recessed 5 mm hex in the top threaded rod, which allows you to install the shock with an open end wrench and a hex drive on a long extension. With the bottom bolt installed, I raised the suspension (jack up the spindle) enough to put some upward pressure on the upper shock assembly (as if the wheel was on and the weight of the car was being supported by the suspension). The shock top nut is secured from turning with an open wrench and then the threaded rod can be turned to tighten the nut with the long 3/8 extension from atop the engine compartment. The replacement nuts are nylock - so they will not come off easily. Just make sure the assembly of bushings is reassembled properly and sitting correctly in the upper shock mount before tightening the upper threaded rod. I could reach the top of both shock in this way fairly easily. I did not have to remove any stuff , but the left side was a little more difficult.
The rears look as though they are another story all together.
gwwaterman is offline   Reply With Quote
Old 06-08-2005, 06:56 PM   #4 (permalink)
Cheers, where did you get your shocks from? Is there any Ajustment needed of the new shocks?
Old 06-09-2005, 07:23 PM   #5 (permalink)
gwwaterman's Avatar
Don's Sport Vehicle Sales - donssport.com
2 BE5-6456-H0 1/99-03 ML320, ML430 Bilstein Heavy Duty Front Shock $102.05 $204.10
2 BE5-2985 1/99-03 ML320, ML430 Bilstein Heavy Duty Rear Shock $147.55 $295.10
The rear shocks do not come with the springs attached. You are supposed to remove the stock assembly and use the old springs to make a new assembly.
There is no adjustment that I am aware of. The fronts can be done by anyone with a clue, but the rears are a bit more troublesome.
