Old 05-25-2005, 10:06 PM   #1 (permalink)
4benzes's Avatar
Vehicle: 4 Mercedes Benz Cars
Send a message via AIM to 4benzes
How long does the comp take to reset(MAF) change
Fellas:
How long will it take for the computer to detect the new MAF?
4benzes is offline   Reply With Quote
Old 05-26-2005, 10:22 AM   #2 (permalink)
rudeney's Avatar
Date registered: Dec 2004
Vehicle: 2001 ML320
RE: How long does the comp take to reset(MAF) change
I assume you mean you had a check engine light, determined it was the MAF, have replaced or cleaned it, and now you want to know when the CE light will go out, assuming the problems is resolved? The answer to that is approximately 20 start-up/shut-down cycles of the engine.
- RODNEY
rudeney is offline   Reply With Quote
Old 05-26-2005, 07:48 PM   #3 (permalink)
jangr320's Avatar
Date registered: Nov 2004
Vehicle: 98 ML320& 05 ML350SE
IIRC, it took less than 6 starts to clear the Check Engine light on the 98ML when I changed it last year.
Dealer said I had to come by for a "reset" / reboot but I didn't have to do that. The car has been into the dealer twice since the MAF swap, and definitely on the OBD last month to check the failed crank sensor. No fault codes came up.
Oh, I bought the MAF new off eBay for $125 and it took less than 15 minutes for the re & re. Dealer quoted $900 including 2.5 hrs labor!!!
jangr320 is offline   Reply With Quote
Old 05-26-2005, 08:33 PM   #4 (permalink)
modojojo's Avatar
Date registered: Jun 2003
Vehicle: 2000 ML320
When I changed my MAF my service tech just reset my comp and my check engine light went off right then and there.
Good deal jang My MAF was 350.00+ 60.00 for labor=410.00 for the whole job, which was still cheaper than the dealer.
modojojo is offline   Reply With Quote
Old 05-27-2005, 11:44 AM   #5 (permalink)
4benzes's Avatar
The magic number was 3
Fellas:
After 3 starts the light was gone[:D]
Old 05-31-2005, 02:34 PM   #6 (permalink)
rudeney's Avatar
Vehicle: 2001 ML320
Keep in mind that a MAF failure is not necessarily “absolute�. It can begin as an intermittent problem and only registers one fault under a certain condition (i.e. RPM, ambient temp and humidity combination). If this is the case, it’s possible that you could restart the engine 15 more times without a fault, then replace the MAF, and it would only take 5 to clear the error code.
- RODNEY
Old 05-31-2005, 07:26 PM   #7 (permalink)
Premium Member
cmitch's Avatar
Date registered: Apr 2005
Vehicle: '99 ML 430, 2002 ML320
Premium Member
When I replaced my mass air flow, it took three on-off starts to clear the code from my computer. An on-off start is usually classified as a start and drive for about 10 minutes each. The computer has to make sure that theproblem has been corrected before it will clear it.
cmitch is offline   Reply With Quote
