» Site Navigation
» Other Sites
Old 03-21-2005, 04:03 PM   #1 (permalink)
pointman's Avatar
Date registered: Sep 2003
04 ml500 clanking noise
on startup, i think on cold starts only.. i get a clanking noise from the motor bay. it eventually goes away. no clue what this noise is. thoughts??
pointman is offline   Reply With Quote
Old 03-21-2005, 04:49 PM   #2 (permalink)
Date registered: Nov 2004
Vehicle: 2001 ML-320
Send a message via Yahoo to davesml320
RE: 04 ml500 clanking noise
Same thing on my 2001 ml 320.... Normal? I'll let ou know what the dealer thinks tomorrow.
Dave
davesml320 is offline   Reply With Quote
Old 03-21-2005, 08:58 PM   #3 (permalink)
pointman's Avatar
great! please dont forget! i appreciate it.
Old 03-22-2005, 12:30 PM   #4 (permalink)
rudeney's Avatar
Date registered: Dec 2004
Vehicle: 2001 ML320
Sometimes I get one "clank" when I start the engine. It sounds like a single tap of a hammer on a metal drum. My truck also makes a very similar sound after it cools down, sort of like a gas can adjusting to a pressure change. I have no clue what it is, but it's done it for years with no other adverse symptoms.
- RODNEY
rudeney is offline   Reply With Quote
Old 03-22-2005, 12:41 PM   #5 (permalink)
Spoke to the SA today and he says that it is "NOT necessarily normal". I will update you as soon as I get the results back fromt he techs...to be continued
Old 03-22-2005, 09:28 PM   #6 (permalink)
pointman's Avatar
davesml320 - 3/22/2005 3:41 PM
thanks, let me know.
Old 03-24-2005, 03:15 PM   #7 (permalink)
Absolutely not normal..If your ML is still under warranty..definitley take it in. Do not take no for an answer. This is a known issue per the SA and tech esp with the V8's.
Hope this helps.
Old 03-24-2005, 04:58 PM   #8 (permalink)
pointman's Avatar
did you hear a solution or exactly what the issue was??? let me know please, thanks.
Old 03-25-2005, 10:44 AM   #9 (permalink)
The Mechanic told me that the ML500 on up are notorious for the valve clank that you are describing.The ML 6 cilinders are not so noticable but it does happen them also.
The fix is to get it in under warranty and have the techs check for damage along the walls of the valve seats or camshaft.
How often does it happen to you?
If you can reproduce it in front of the mechanic they WILL check it out for you.
They could not reproduce the clank that I had but he said to bring it in if I hear it getting worse.
Dave
Old 03-25-2005, 11:43 AM   #10 (permalink)
pointman's Avatar
oh whoa! thanks for letting me know. but it only seems to happen on cold start up. the initial start in the morning.
