» Site Navigation
» Other Sites
Old 03-08-2005, 03:37 PM   #1 (permalink)
pize98's Avatar
Date registered: Feb 2003
Vehicle: 1999 ML320 (Sold)
75,000 mile service
I'm bringing the ML in for 75,000 service. I haven't done much but change the oil. I have heard of some people changing shocks at this mileage, also changing the fuel filter, transmission fluid, what do you guys recommend I guess I wouldnt want to spend more than 1500.00 this time around. Any input would be appreciated.
pize98 is offline   Reply With Quote
Old 03-08-2005, 03:48 PM   #2 (permalink)
MLOffRoad's Avatar
Date registered: Feb 2005
Vehicle: Mercedes "M32"
RE: 75,000 mile service
I would do all fluids anfd filters ... the rest should be fine. 75,000 miles is still VERY young for other parts to go bad, unless you beat on her.
285-75-16 (33.1") BFG Mud-Terrains, Black Powdercoated Wheels, ORC Lift Kit, H&R 1" Wheel Spacers all-around, Paintmatched Bumpers, Flares & Clading, Updated Headlights, 6000K Xtec HID's, Silverstar Blinkers, WAAG Full Front Brushguard, Custom Fabricated Winch Mount, Warn XD9000i, 16500# MasterPull Synthetic Cable, PIAA Pencil-Beam 580's, 5% + 15% Tint All Around & 30% down the windshield, Custom Magnaflow Exhaust, K&N Drop-In.
MLOffRoad is offline   Reply With Quote
Old 03-09-2005, 08:38 AM   #3 (permalink)
pize98's Avatar
well I'm getting the transmission fluid changed (even though my SA says it never needs to be changed) transfer case, front and rear axle, fuel filter and plugs. Anyone know what the damage might be around 1500?
Old 03-09-2005, 09:04 AM   #4 (permalink)
roadsession's Avatar
Date registered: Nov 2002
Vehicle: 99 ML320 C230 530i
pize98 - 3/9/2005 11:38 AM
That's an excellent list of things to do.
She will go another 75k miles easily if you do above.
Trransfer case, axle, transmission fluid change will be total around $400.
Spark plugs - buy on line from one of the sponsors here and save about $100. They will charge you probably around $300 to change the plugs (labor). The plugs have to be changed within 4 years even if they haven't reached 100K miles on the 98 and 99's.
Fuel Filter - I say if you use very good quality gas with detergents, and you're not having problems, don't bother changing. If however you really want to do it, factor in about $800-$1K for the parts and labor.
Your ML is a labor of love and it physically shows. Enjoy
roadsession is offline   Reply With Quote
Old 03-09-2005, 09:24 AM   #5 (permalink)
pize98's Avatar
thanks for the reply's this is a great forum to be part of.
Old 03-09-2005, 10:58 AM   #6 (permalink)
Date registered: Sep 2003
Vehicle: ML 320
I agree with roadsession.
I would also add the following:
- air filter (depending on when it was last changed). This can also help to prolong the MAF sensor.
- replace cabin air filter with the new bosch charcol filter (again, depending on when it was last changed).
- check your catalytic converters. Early model years had problems with the weld and they would crack. I think that these are still covered by a federally mandated warranty up to 80,000 miles. Otherwise, I hear that they are about $1,500 each.
- check for any other typical problems like the D-pillar, door locks, etc... If you have a good relationship with your dealer and are having all of the other maintanence done by them, now is a good time to ask for a partial good will on repairs of any known defects.
RickT is offline   Reply With Quote
Old 03-09-2005, 02:29 PM   #7 (permalink)
Vehicle: 98ML320
I know this was covered in part on this thread but just to reiterate, here are some things to check off your list and make sure your current on (per the manual)
Every 4 years it will need an air filter, fuel filter and spark plugs.
Coolant flush every 3 years.
Brake fluid flush every 2 years.
bigcatny is offline   Reply With Quote
Old 03-15-2005, 09:13 PM   #8 (permalink)
pize98's Avatar
While in for service they are replacing the harmonic balancer and belt for me which I thought was pretty cool. Only thing is it needs rotors and pads in the back and pads in the front looking at probably 2500.00 with all the work. Between the service and the navigation install this baby better run to 175,000 miles.
Old 03-15-2005, 09:25 PM   #9 (permalink)
MLOffRoad's Avatar
pize98 - 3/16/2005 12:13 AM
No sweat .. I think all ML's could run till over 200,000 miles if taken care of properly. [:)]
