Old 01-19-2005, 07:44 PM   #1 (permalink)
ALo
Date registered: Aug 2004
Vehicle: '99 ML430
Power steering rack - fluid is coming through
Hi,
I have seen a lot of messages about leaking steering system. I located mine and it is under the car in so called steering rack. There are two 'pumps"? Or actually I dont know what they are. Could someone help out a little bit. The two lines (metal hoses) are obviously output and input . I think both are leaking. Is there a way to tighten them? They have star looking "bolt" in the end where hoses comes/goes.
_Al[?]
ALo is offline   Reply With Quote
Old 01-19-2005, 07:51 PM   #2 (permalink)
roadsession's Avatar
Date registered: Nov 2002
Vehicle: 99 ML320 C230 530xi
RE: Power steering rack - fluid is coming through
ALo - 1/19/2005 10:44 PM
Hi,
_Al[?]
do a search on steering rack leak.
Lots of info on this.
I had my leak fixed by replacing the o rings.
roadsession is offline   Reply With Quote
Old 01-19-2005, 08:05 PM   #3 (permalink)
ALo
Vehicle: '99 ML430
allright. yeah it looks like lot of people have similar kind of issues with ML's. Did you have the leak in power steering rack? How much was the fixing work approximately?
Old 01-19-2005, 11:54 PM   #4 (permalink)
4benzes's Avatar
Vehicle: 4 Mercedes Benz Cars
Send a message via AIM to 4benzes
yes you can tighten the lines. they have 2 torx heads on them. on my 99, i had a leak only when the system was under pressure. the dealer could not find it. the fluid would not come out until i parked after driving. I climbed under the vehicle and tightend the torx bolts on the rack----no more problem[:D]
4benzes is offline   Reply With Quote
Old 01-20-2005, 09:33 AM   #5 (permalink)
ALo
Vehicle: '99 ML430
What sort of tool you used for them (is it a wrench)? It is still kind of hard area to work (lack of space...)
Old 01-20-2005, 10:41 AM   #6 (permalink)
ALo - 1/20/2005 12:33 PM
I assume from this question you are not a strong DIY guy.
I do not recommend you attempt this repair yourself.
Bite the bullet and take it to a shop
Old 01-20-2005, 10:45 AM   #7 (permalink)
ALo
Vehicle: '99 ML430
I was just wondering that it is not a torx head I have ever seen. It must need a strong arm to loose or tighten it...
Old 01-20-2005, 11:03 AM   #8 (permalink)
ALo - 1/20/2005 1:45 PM
Sorry, it was wrong of me to assume that....
Anyway, I see from your other post you've changed your own Crankshaft sensor. This should be a DIY if you can manage, but usually the fix involves removing the lines and replacing the rubber orings with neoprene ones.
I could'nt get the nuts to budge - the tech at the dealer used a really long cheater bar and it took all his might to get it loose. He had special tools too...
Which is why I think the standard fix at the dealer is to replace the entire steering rack...
Which is also why I don't recommend this as a DIY
Good luck
Old 01-20-2005, 11:58 AM   #9 (permalink)
ALo
Vehicle: '99 ML430
allright. Thanks for the ideas. I will try it out tonight and if cant do will take it to somewhere. Hopefully it is only those O-rings...It sounds like it but never know...
