Old 10-01-2004, 12:39 AM   #1 (permalink)
Date registered: Sep 2004
99 ML320 Shifting Problems. HELP!
After going through the many threads regarding transmission issues, I have yet to pinpoint exactly what my problem is. I have a 99 ML320, that is out of warranty. A very good friend of mine is a ASE master technician and he is helping me repair the vehicle. He has the scantools to extract tranny codes, so I have those codes available to anyone who could help me out.
Anyhow, a couple months ago, every couple of days the car would either not shift up into a higher gear, stuck in 2nd gear it seems, or get stuckin 3-4th gear, and will not downshift when vehicle has slowed down to a stop. This means at a stop light it would accelerate extremely slow due to the higher gear. I would then turn the car off and turn it back on, and the problem would be gone. Back to normal.
A couple of days ago, the problem has came back, but this time, it is here for good. I tried turning off and back on to no avail. So right now, it wont upshift past 2nd gear. I initially presumed it was limp mode related, but my friend says a code related to the RPM sensor is being indicated in the check engine light.
He is a very talented technician, but has limited knowledge regarding new MBs. I was hoping someone here experienced the same problem and could help me out. I would hate to bring it to dealer and deal with those sharks.
Thanks.
xbrxx is offline   Reply With Quote
Old 10-01-2004, 05:26 AM   #2 (permalink)
00 ML430 Bulldog's Avatar
Date registered: Mar 2003
Vehicle: 2000 ML430
RE: 99 ML320 Shifting Problems. HELP!
xbrxx - 10/1/2004 2:39 AM
Thanks.
You can post your technical questions here http://www.mercedesshop.com/shopforu...splay.php3?f=1 and here http://www.mercedesshop.com/shopforu...play.php3?f=17 and a MB Tech will help you.
ONE TUFF LOOKING ML!!!
00 ML430 Bulldog is offline   Reply With Quote
Old 10-01-2004, 06:44 AM   #3 (permalink)
roadsession's Avatar
Date registered: Nov 2002
Vehicle: 99 ML320 C230 530xi
Do a search on THIS FORUM for transmission fluid change
You will get results like:
http://www.mbnz.org/forums/forums/thread-view.asp?tid=1182444&posts=7&hl=transmission+fluid +change
BMW E60 530xi
MB W163 ML320
MB W202 C230
roadsession is offline   Reply With Quote
