Old 09-27-2004, 08:02 AM   #1 (permalink)
Vehicle: '05 ML350SE
Console cupholder cleaning hint for 02+
If you are like me and use the center console cupholder as a storage bin then it needs periodic cleaning. I have found that it can be removed.
Simply grab the holder and push it to the rear of the truck. You will hear the snap locks disengage and the holder will feel loose. It is then easy to remove the holder as a single unit and clean as you see fit. Reverse your steps to install.
Tom DeTemple
Denver
'99 ML320 traded @139k miles for---
'02 ML320 traded @45k miles for---
'05 ML350SE now at 50k+ miles
mickey.1430 is offline   Reply With Quote
Old 09-30-2004, 05:37 PM   #2 (permalink)
Date registered: Sep 2004
Vehicle: 2004 ML350
RE: Console cupholder cleaning hint for 02+
I knew I could pluck out the little rubber mat but I had no idea the cupholder snapped out so easily. Makes it easy to put a bit of grease on the side rails when the movement gets sticky.
2004 ML350 Black with charcoal leather, OEM Hitch, Rhino step, Bose, Navigation, OEM front guard, Comfort package, Entertainment package, Sunroof, heated seats.
2bmj is offline   Reply With Quote
