Old 09-19-2004, 08:46 PM   #1 (permalink)
roadsession's Avatar
Date registered: Nov 2002
Vehicle: 99 ML320 C230 530xi
rear seat removal - easy or hard?
I am going to remove my rear seat in the next few days - there is this annoying groan/squeak from the rear seats and I am hoping to remove it and put some sort of backing to where the seat mounts to the floor.
Is this easy or hard? Any tips...
Thanks
BMW E60 530xi
MB W163 ML320
MB W202 C230
roadsession is offline   Reply With Quote
Old 09-19-2004, 10:40 PM   #2 (permalink)
Darkmann's Avatar
Vehicle: Anything w/Wheels
It's not hard at all. There are male torx fasteners that hold the seat to the
floor - don't recall what the size is, but get a set of torx wrenches. You'll need some thread locker (I used Locktite brand - the medium strength, just in case I have to remove the seats again. Be careful with the seat belt sensor harness - it's tricky to unlock. The plastic floor trims are also tricky to undo. Be careful not to break a tab or you'll be loking at more rattles. If you do happen to damage them and you don't have a VES and your's is MY02+, I have a brand new set if you want, for free - they came off when I installed the VES. Other than that, be careful lifting the 65% seat, it's heavy!!! Good luck.
1989 300ZXT - mine
A pair of running shoes
A 18Hp lawn mower
2 Mountain Bikes
350Z - will be mine when @ 300+HP and 3-Car Garage
Darkmann is offline   Reply With Quote
Old 09-20-2004, 05:17 AM   #3 (permalink)
RE: It's not hard at all. There are male torx fasteners that hold the seat to the
Darkmann - 9/20/2004 12:40 AM
Thanks Darkmann!
Old 09-20-2004, 01:59 PM   #4 (permalink)
UncAl's Avatar
Date registered: Sep 2002
Vehicle: '08 Acura MDX
RE: rear seat removal - easy or hard?
I used a 7/16" 12pt socket.
_______________
'08 Acura MDX w/ Tech package
Previously - '98 ML320 - 285k miles in 7 years
UncAl is offline   Reply With Quote
Old 09-20-2004, 02:11 PM   #5 (permalink)
11 mm 12 pt socket seems to work as well...
Old 09-22-2004, 01:41 AM   #6 (permalink)
ae86pwr's Avatar
Date registered: Nov 2003
Vehicle: 98 ML320 / 06 S2000
Send a message via AIM to ae86pwr Send a message via MSN to ae86pwr
I've found an annoying rattle inside the left C-pillar ... will try to pull the panel out this weekend to look for it ... anyone had that before?
ae86pwr is offline   Reply With Quote
Old 09-22-2004, 05:21 AM   #7 (permalink)
ae86pwr - 9/22/2004 3:41 AM
are you sure it's not the seat belt latch rattling against the door?
Old 09-22-2004, 12:55 PM   #8 (permalink)
ae86pwr's Avatar
roadsession - 9/23/2004 4:21 PM
I tried that long ago .. I buckled up all the seatbelts in the back and still there
Old 02-17-2005, 12:09 AM   #9 (permalink)
tsanjose's Avatar
Vehicle: 2000 ML430
Send a message via ICQ to tsanjose Send a message via AIM to tsanjose Send a message via Yahoo to tsanjose
so how many bolts are there to remove the rear seats? hey darkman, can you show us how to remove the plastic panels under the seats? i need to run some wiring under there.
paul said he had to stick a tire iron inside cause of the carpet being glued down.
tsanjose is offline   Reply With Quote
Old 02-17-2005, 08:18 AM   #10 (permalink)
MLOffRoad's Avatar
Date registered: Feb 2005
Vehicle: Mercedes "M32"
Good thread ... I have to take out my seats to do some hard-core detailing. Does anyone know how hard the fronts are to take off ??
285-75-16 (33.1") BFG Mud-Terrains, Black Powdercoated Wheels, ORC Lift Kit, H&R 1" Wheel Spacers all-around, Paintmatched Bumpers, Flares & Clading, Updated Headlights, 6000K Xtec HID's, Silverstar Blinkers, WAAG Full Front Brushguard, Custom Fabricated Winch Mount, Warn XD9000i, 16500# MasterPull Synthetic Cable, PIAA Pencil-Beam 580's, 5% + 15% Tint All Around & 30% down the windshield, Custom Magnaflow Exhaust, K&N Drop-In.
MLOffRoad is offline   Reply With Quote
