For 2000+ ML430: You don't touch those four torx screw on the side of the calipers
For Pre-2000: It is the same as the ML320 where you only need to remove the Sliding Torx bolt T-38 or T-40 (i forgot which one) If you are removing the the brake disc then you need the 5mm hex screw.
