Old 09-01-2004, 03:13 PM   #1 (permalink)
Date registered: Sep 2003
Vehicle: 04 ML350 04 CLK conv
How to fix bumper scratches
Someone did this deep scratch to my rear bumper (see attached picture). Probably he or she was pulling in or out of the parking spot.
I would appreciate any help on how to fix it.
Thanks everybody.
celm77 is offline   Reply With Quote
Old 09-01-2004, 03:42 PM   #2 (permalink)
phoenix44's Avatar
Date registered: Aug 2004
Vehicle: '01 ML55
RE: How to fix bumper scratches
the "rule" so I am told, is if your finger nail can get a grip on the scratch, it is off to the body shop.
However, you might be able to build it up with layers of either touch up paint/pen and than use som mid to fine polish. There is a plastic polish called NOVUS, I have used it with great results.
phoenix44 is offline   Reply With Quote
Old 09-01-2004, 03:43 PM   #3 (permalink)
teky's Avatar
Date registered: Jun 2004
Vehicle: chris
remove what you can with T-cut then fill with finishing paste then apply touch up paint, personally i don't worry about these things because it always happens but the best/cheapest job is through private not dealer
teky is offline   Reply With Quote
Old 09-01-2004, 05:38 PM   #4 (permalink)
sthu's Avatar
Vehicle: W163/W115
Send a message via Yahoo to sthu
Are you sure what you see is not the material (rubber/plastic) transferred from their bumper? If it is, obviously you can just rub it out.
Else you can try two ways:
One: use touch up paint in multiple layers and try wet sand, rubbing compound and polish to smooth it out.
Two: professional body shop.
"de gustibus non est disputandem" ~ No accounting for taste
W163, W115, Matrix
1996 115lb Yellow Lab
sthu is offline   Reply With Quote
Old 09-01-2004, 05:49 PM   #5 (permalink)
phoenix44's Avatar
Vehicle: '01 ML55
sthu - 9/1/2004 7:38 PM
All is great, You just need to be REALLY, REALLY carefull about wet sanding.
Old 09-01-2004, 07:03 PM   #6 (permalink)
STHU
The black scratch you see in the picture is where the paint has come off totally. So it is not dirt or so,
it is the bare plastic of the bumper[:(]
Old 09-01-2004, 07:43 PM   #7 (permalink)
sthu's Avatar
Vehicle: W163/W115
I took our ML to Airport Collision Center in Manassas and they did a great job. It was for the front bumper. I saw them doing touch up on Ferrari and Porsche, so I figured they are competent(sp) enough to do our ML. [:D]
