Old 08-09-2004, 04:48 PM   #1 (permalink)
phoenix44's Avatar
Date registered: Aug 2004
Vehicle: '01 ML55
power door lock actuator
Hi,
Anyone know if there is a simple fix for a door lock actuator. When attempting to lock the door, the actuator clicks rapidly up and down.
phoenix44 is offline   Reply With Quote
Old 08-09-2004, 06:24 PM   #2 (permalink)
dewdaltz's Avatar
Date registered: Oct 2002
Vehicle: 02ML320 & 06RClass
RE: power door lock actuator
phoenix44 - 8/9/2004 6:48 PM
Hi,
If you still have the warranty, best place is the dealer. I had mine fixed too. JUst came out from the mall, open the driver side then suddenly the door lock went up and down. Called my SA dropped the ML the next day. NO problemo.
Quote 4 da` day : MODDING is very essential to make your ML very SPECIAL
dewdaltz is online now   Reply With Quote
Old 08-09-2004, 07:07 PM   #3 (permalink)
phoenix44's Avatar
Vehicle: '01 ML55
........warranty ended a couple of months ago.
Old 08-09-2004, 09:40 PM   #4 (permalink)
Vehicle: 98ML320
The fix is to replace the offending door lock mechanism. If your comfortable with removing and reinstalling pop rivets then it's probably a medium technical ability fix. If not then any half decent mechanic can do the work.
Note: The only tricky part is removing the lock cylinder. Or actually, figuring it out and having the extra long hex wrench.
bigcatny is offline   Reply With Quote
