» Site Navigation
» Other Sites
Old 08-08-2004, 07:39 PM   #1 (permalink)
roadsession's Avatar
Date registered: Nov 2002
Vehicle: 99 ML320 C230 530i
Transmission & Transfer Case Fluid Changed
Ok, bit the bullet. Original owner of 99 ML320 with 75K miles - and want to keep it for a while. So I talked with a MB Master Mechanic (he has a 99 ML320 as well) and he also did a transmission and transfer case fluid change.
Was quoted $400 to do the change, but in the process, discovered that the transmission lines were leaking - so total bill was $1000 for everything. Dealer goodwilled so much previous work I figured I'll pay this one.
The ML is fully paid for, and I love this truck, so I really don't mind these maintenance investments...
But anyway, back to the fluid change - the so called lifetime fluid was completely black and very thin. The mechanic said the reason they call it lifetime is that these days 100K Miles is considered lifetime.
The ML shifts noticeably smoother, and am glad I got it done - peace of mind frankly. Highly recommended!
Anyway, the procedure for fluid change is rather complex - and dealer has to use a special dipstick...Anyway I highly recommend you get your transmission fluid changed if you are running either 100K miles or it's been the same fluid for the past 5 yrs or so....
roadsession is offline   Reply With Quote
Old 08-08-2004, 07:49 PM   #2 (permalink)
C-Rod's Avatar
Date registered: Oct 2002
Vehicle: 2006 ML 350.
RE: Transmission & Transfer Case Fluid Changed
l have to agree..l had the transmission oil changed as well around 90,000 KM's..my SA, who is a great guy, said it looked horrible..enough said...How much would it cost for just the transfer case [?][?]
1999 : Black Opal ML 430 : 125,000 KM (traded-in)
2002 : Bordeaux ML 55 : 130,000 KM (traded-in)
2006 : Silver lridium ML 350 : 53,000 KM (stolen)
2006 : Cubanite Silver Metallic : 24,000 KM
C-Rod is offline   Reply With Quote
Old 08-08-2004, 08:51 PM   #3 (permalink)
Vehicle: '05 ML350SE
The transfer case uses Dextron III which is relatively low cost
ATF fluid. I did the transfer case and both diffs on my MY99 for a little over $100 two years ago. It is basically a time charge.
Tom DeTemple
Denver
'99 ML320 traded @139k miles for---
'02 ML320 traded @45k miles for---
'05 ML350SE now at 48k miles
mickey.1430 is offline   Reply With Quote
Old 08-08-2004, 09:10 PM   #4 (permalink)
Date registered: Jul 2004
RE: The transfer case uses Dextron III which is relatively low cost
T-case uses tranz fluid huh? Anyone know how much it takes? I just ordered a case (12qts) of tranny fluid and a filter, but kinda forgot about the T-case. I guess I'll do that too if I have enough fluid.
Chevota is offline   Reply With Quote
Old 08-09-2004, 08:06 AM   #5 (permalink)
The transfer case has 1.6 qts. capacity
Old 08-09-2004, 12:06 PM   #6 (permalink)
RE: The transfer case has 1.6 qts. capacity
Thanks Mickey, I was expecting more like 3-4. I was also expecting it to use gear oil.
Sweet, I'll change both this week.
The fluid in the tranz is nasty (75k), black and smells old. Worst tranz fluid I've seen in a car that was still running right.
Old 08-09-2004, 12:59 PM   #7 (permalink)
Mine stunk like a locker room. The same happens for high
quality oils used in vacuum stations. The lower the ultimate vacuum, the more stench. I could never figure that out.
I did read somewhere that some techs use a smell test to tell them when it is time to change tranny fluid.
How the heck does one quantify that?
Old 08-09-2004, 05:13 PM   #8 (permalink)
RE: Mine stunk like a locker room. The same happens for high
Vacuum stations? I guess I don't follow.
It's easy to tell when it's "not so fresh", new trans fluid has a distinct smell. After some time and heat it’s not so fresh, kinda like me. As time passes I smell less fresh chemicals, and more burned oil, clutch and metal. If all is well it just smells less fresh. Mine worries me because it’s so filthy, smells a bit of clutch, and the viscosity seems shot. That and everyone says these trannys have a short life.
Smell some new fluid out of a bottle, and then some from different cars, you’ll know. Same with motor oil, rub some new oil between your fingers very firmly, it’s thick and very difficult to remove. Then after your fingers are squeaky clean, try used oil from a few dipsticks, the really worn out stuff is very thin and rubs/washes off ten times easier. This is how I judge if my oil needs changing, not by miles. Some vehicles like my truck break down oil very fast, 10K miles on a change would be a bad idea.
Old 08-23-2004, 08:42 PM   #9 (permalink)
ae86pwr's Avatar
Date registered: Nov 2003
Vehicle: 98 ML320 / 06 S2000
Send a message via AIM to ae86pwr Send a message via MSN to ae86pwr
$288.45 transmission fluid change
parts: Gasket, Trans Oil Filter, Seal Ring, Trans Fluid, Ring, General, Lock Pin.
Comment:
CLIENT REQUEST SERVICE TRANSMISSION** TIME TO REMOVE TRANSMISSION OIL PAN, DRAIN TORQUE CONVERTOR, REPLACE TRANSMISSION FILTER AND PAN GASKET 2.0CP** (NOTE WHEN PAN WAS DOWN FOUND GRAPHITE PRESENT IN FLUID, ALSO FOUND SOME TRACES OF PLATE MATERIAL, METAL SHAVINGS, WHEN CHECK FLUID LEVEL FOUND ADAPTION DATA ON 2-3 AT 99 AND 150 ALSO FOUND 3-4 AT 81 AND 165)
what was exactly is adaption data??
Denis
ae86pwr is offline   Reply With Quote
Old 09-10-2004, 02:44 PM   #10 (permalink)
nimit's Avatar
Date registered: Aug 2004
Vehicle: 1999 ML 320
roadsession where did you go to get this done?
just wondering was there anyone else around MA that got a price cheaper than $400?
nimit is offline   Reply With Quote
