» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W163 M-Class
Old 07-06-2004, 07:33 PM   #1 (permalink)
Date registered: Feb 2004
Vehicle: 2004 ML
Location of Amplifier for "premier" Bose system??
I have an ML350 with the "premier" Bose system, which sounds "unpremier" and I'm dying to upgrade. Does anyone know where the amp for the Bose system is located? I'm looking at bypassing this amp and putting in my own amp and new speakers. Are they separate amps for the front and rear spkrs or just one amp? And what abt the sub under the driver's seat - is there an inbuilt amp in the sub's box?
Thanks
Dave.
dmbenzworld is offline   Reply With Quote
Old 07-06-2004, 09:53 PM   #2 (permalink)
Date registered: Jan 2004
Vehicle: 2004 ML500,Sport
Send a message via AIM to johnma
RE: Location of Amplifier for "premier" Bose system??
Amp for Bose speakers are build into the speakers it self. It's 1 mono amp per speaker.
JM
johnma is offline   Reply With Quote
Old 07-06-2004, 11:15 PM   #3 (permalink)
flaxcon's Avatar
Date registered: Apr 2004
Vehicle: 1989 300E
Subwoofer is under the seat. I am assuming that this is the amplifier that you are looking for. It is on the drivers side bolted to the floor. Aust look under the seat.
flaxcon is offline   Reply With Quote
Old 07-07-2004, 02:31 AM   #4 (permalink)
scorchie's Avatar
Vehicle: CLK55/G500/E55/ML55/etc.
johnma - 7/6/2004 9:53 PM
JM
Do you have any further information to support that statement? Because I was looking through the wiring diagrams and they don't seem to agree... but then again, I could be reading them completely wrong.
-s-
1987 190E / 1987 300E x2/ 2001 CLK55 / 2001 ML55 / 2002 G500 / 2003 E55 / 2006 R350 / 2006 G450 / 2007 sumtin sumtin
scorchie is offline   Reply With Quote
Old 07-07-2004, 02:39 AM   #5 (permalink)
scorchie's Avatar
dmbenzworld - 7/6/2004 7:33 PM
Thanks
Dave.
It depends on where your vehicle was manufactured for (e.g. US-spec), and the model year.
If you have code 810 sound system, the main amplifier should be under the dash and is accessed by removing the cover below the instrument panel on the left side (regardless of left hand drive or right hand drive).
-s-
Old 10-19-2005, 10:57 AM   #6 (permalink)
ToneMonday's Avatar
Date registered: Sep 2005
Vehicle: 01 ML55 AMG
I am in the process of replacing my system and the Bose amps ARE not on the speakers, nor in the doors, nor under the dash. It appears that the amps may be incorporated with the sub. Will post after pulling the sub.
ToneMonday is offline   Reply With Quote
Old 10-19-2005, 01:54 PM   #7 (permalink)
rudeney's Avatar
Date registered: Dec 2004
Vehicle: 2002 C240 (current), 2001 ML320 (former)
On a MY2004 US-spec ML with the Bose system, the amp is connected via the D2B fiber optic bus and is located on the firewall (IIRC, just above the driver’s footwell). AFAIK, you won’t be able to just swap out this amp. If you are really unhappy with the Bose system, your best bet is to completely replace it – head unit, amp, speakers and all. Note that removing the MCS will deactivate the D2B fiber optic system and thus disable Teleaid.
- RODNEY
rudeney is offline   Reply With Quote
Old 10-19-2005, 02:10 PM   #8 (permalink)
ToneMonday's Avatar
I've got my AVIC-D1 connected to the Bose amps that I still cannot physically locate but at least I am back up. No amp on my firewall in my US ML55
Old 10-19-2005, 06:57 PM   #9 (permalink)
Vehicle: 2004 ML
Its here for mine - 2004 premium Bose - behind the driver's side firewall - see pic.
Old 10-19-2005, 07:51 PM   #10 (permalink)
samhmbz's Avatar
Date registered: Oct 2004
Vehicle: W211.056C209W202W124
ToneMonday - 10/19/2005 1:10 PM
Your amp is located in the same place as the picure above shows. If its not then it has been removed or the AMG vehicle some how is not equipped with one.(I doubt that)
There is a foam liner blocking it.
Hope this helps. [:)]
Sam
Free maintenance ? buy a Bimmer......
samhmbz is offline   Reply With Quote
