Old 06-06-2004, 07:46 AM   #1 (permalink)
TWhyte's Avatar
Date registered: Jun 2004
Vehicle: 1998 ML 320
1998 ML 320 won't start
The vehicle was running fine, stopped at a store and shut the vehicle off, when I came back out which was all of two minutes the vehicle would not start. After talking with mercedes roadside assist, replaced the battery, the car would then turn over and start for a breif moment then shut off, again going off thier lead they felt it was the fuel pump which I replaced the next day. The vehicle is still doing the same thing. There seems to be fuel getting the engine for when you push the fuel presure release valve fuel does come out. Any ideas ???
TWhyte is offline   Reply With Quote
Old 06-06-2004, 09:34 AM   #2 (permalink)
00 ML430 Bulldog's Avatar
Date registered: Mar 2003
Vehicle: 2000 ML430
RE: 1998 ML 320 won't start
Try using your spare key. It might be your imobilizer acting up if not it might be your crankshaft position sensor.
ONE TUFF LOOKING ML!!!
00 ML430 Bulldog is offline   Reply With Quote
Old 06-06-2004, 09:58 AM   #3 (permalink)
Steve (Austria)'s Avatar
Vehicle: 2006 ML 320 CDI
This sounds like a problem with your key. I had the same thing when I tried using my spare. The car would open and turn over, but not catch! Otherwise it could be an electrical problem with the immobilizer. I dont know if there is maybe a fuse you could check ?
Good luck!
2006 ML 320 CDI
Steve (Austria) is offline   Reply With Quote
Old 06-06-2004, 12:39 PM   #4 (permalink)
TWhyte's Avatar
That was the problem, I used my other key and it runs fine. Does anyone know why the key goes bad ? and what is the imobilizer ? Thanks alot for steering me in the right direction, so much for Mercedes road side assistants.
Old 06-06-2004, 02:39 PM   #5 (permalink)
Bubbenz's Avatar
Date registered: May 2004
Send a message via AIM to Bubbenz
I feel so fortunate to have read this, I experienced the same problem last week and my ml is still at the dealer and they wanted me to replace the entire alarm system for ~$1000. I am just going to get a key made and see if that starts it. Thanks for the help.
Bubbenz is offline   Reply With Quote
Old 06-06-2004, 03:38 PM   #6 (permalink)
ScubaDriver's Avatar
Date registered: Sep 2002
Vehicle: 1999 ML320
My 1999 ML320 did the same thing two weeks ago (see my post stranded 120 miles from home). It was the crankshaft positioning sensor. Cost around $450.00 US. Good luck, hope it works out to be just your key!
ScubaDriver is offline   Reply With Quote
Old 06-06-2004, 04:17 PM   #7 (permalink)
Date registered: Feb 2003
Vehicle: 2006 ML350
This happened to me 150 mi. from home with no
second key (98 ML320). Had to have a new key air expressed in. Don't know exactly why it happens, but seems to be somewhat common.
<HTML>
<B>Greg</B> Lake Oswego, Oregon, USA
<HR>
<B>2006 ML350</b> - Pewter/Charcoal Alcantara/Aluminum; Packages: Comfort, Lighting, Entertainment, Appearance, Airmatic, Sunroof; Options: Nav, Sirius, hitch, heated seats, power liftgate, roof rack; Mods: ML500 skid plates, ML63 20" wheels.
<B>2001 BMW M3 Coupe</B> (5/01 prod.) - Titanium/Cinnamon w/ many mods.
GregW / Oregon is offline   Reply With Quote
Old 06-07-2004, 02:36 PM   #8 (permalink)
Vehicle: 99 ML320
Ignition system. I purchased my 99 ML 2 weeks ago and 10 days in it wouldn't start after filling up at the gas station. Called for a tow, after waiting about 10 min it started right up. Canceled the tow, assumed it was just a fluke as I had let the tank run nearly dry.
Happened again that night as I dropped a friend off. Waited, started. Next morning got up to take it to the dealership, did it again.. waited; started. As I pulled up into the garage, it died a fourth time, wouldn't start. After making certain the technician heard it turning over I left it with him.
I got a call a few hours ago. They thought it was the feul pump, it tested pressure, pressure, pressure, zero; several times. Eventually though, they tracked it down to a faulty ignition system. It would fail and send a signal to the pump to stop sending fuel.
May be a 180ΒΊ from your problem, but this could be the issue.
M
miguel446 is offline   Reply With Quote
Old 06-07-2004, 02:36 PM   #9 (permalink)
Vehicle: 99 ML320
May be a 180ΒΊ from your problem, but this could also be the issue.
M
Old 06-08-2004, 04:43 PM   #10 (permalink)
Bubbenz's Avatar
I purchased a new key from the dealer, they programmed it, and it started fine!
