Old 05-11-2004, 09:59 AM   #1 (permalink)
R3Wood's Avatar
Date registered: May 2004
Vehicle: '86 560SL '02 ML320
Where to Purchase Bi-Xenon for 1999 ML320?
Hello,
Does anyone know of another place besides Performance Products to buy a Complete Bi-Xenon Light Assembly for a 1999 ML320.
Also, my '99 has the fogs programmed next to the stock halogen headlamps (where flash-to-pass would be on the newer assembly). The connector for the programmed fogs, would not be used for flash-to-pass on the new Bi-Xenon assembly? Is that correct?
Rich
Somers Point, NJ
'02 ML320
'99 ML320
'86 560SL
R3Wood is offline   Reply With Quote
Old 05-11-2004, 02:50 PM   #2 (permalink)
Tim
Vehicle: 2001 ML320
RE: Where to Purchase Bi-Xenon for 1999 ML320?
That is correct. If you want fogs when adding the 2002 lights, you can add a set external fogs and connect them to the already prewired cable for this. (It is located next to the fan) The dash switch also switches this fog cable.
<a href="http://www.urbanplanet.org/" target="_blank"
title="Visit UrbanPlanet.org"><img
src="http://www.midtechonline.com/images/banners/up_citytalk_88x15.gif"
width="80" height="15" border="0" alt="Visit UrbanPlanet.org"></a>
Tim is offline   Reply With Quote
Old 05-12-2004, 04:31 AM   #3 (permalink)
R3Wood's Avatar
Thanks Tim!
Old 05-12-2004, 08:09 AM   #4 (permalink)
Vehicle: 98ML320
If you do get the bi-xenon's you'll probably find that you won't need the foglights for the light as the xenons do such a great job. You may however want the fogs for the visual appeal.
Good luck[8D]
bigcatny is offline   Reply With Quote
Old 05-12-2004, 11:45 AM   #5 (permalink)
Date registered: Sep 2003
Vehicle: ML 320
When I looked for the Xenon lights, PP offered the best deal with a 10% discount to BW members.
You can also check the site sponsors for other sources. E n g i s o f t (the web server would not allow me to enter the name correctly) also offers them, and usually matches prices.
Finally, I too have a 99. As far as I can tell, there is no programming required for the Xenons. I watched the shop forman look in the computer to see if they could find a setting to change, but there was nothing. Mine were just plug and play.
RickT is offline   Reply With Quote
Old 05-12-2004, 01:08 PM   #6 (permalink)
wickedml's Avatar
Vehicle: 2001 ML320 sport
what about installing bi xenons for a 2001 ml320. would that be plug and play or would i have to go to the dealer and have them program it to work? I mean, i already have xenons, but i want to updated look of the 2002+???[:D]
wickedml is offline   Reply With Quote
Old 05-12-2004, 01:20 PM   #7 (permalink)
Vehicle: 2002 ML55K
Send a message via AIM to jdbower Send a message via MSN to jdbower
Plug and play from PP. You need a pigtail adapter which they include. By far the most useful upgrade for a pre-02 - other than a blower of course![}:)]
Thanks,
Jeff
<hr><small>2002 ML55 (debadged), <A HREF="http://www.benzworld.org/forums/forums/thread-view.asp?tid=46299&posts=20" target="_blank">Metallic Black Rear Star</A>, 2003 DVD Navigation, fire extinguisher, OEM trailer hitch, OEM Smoke Hood Deflector, OEM Smoke Sunroof Deflector, OEM basic carrier, v60, VES, CD Changer, <A HREF="http://www.*************.com/contsp/product.asp?intProdID=D-ML163-LED-Painted&model=W163&category=LED+Brake+Lights+" target="_blank">LED rear wing</A>, <A HREF="http://www.*************.com/mb_results_m.asp?model=W163&class=m-class&category=LED+Replacement+Bulbs" target="_blank">LED brakes and rear turn signals</A>, <A HREF="https://www.designtech-intl.com/merchant.ihtml?pid=47&lastcatid=12&step=4" target="_blank">DesignTech halogen backup bulbs</A>, <A HREF="http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&category%5Fname=CT LG%5F010%5F012%5F011%5F000&product%5Fid=276%2D272" target="_blank">amber ambiant passenger footwell lighting</A>, <A HREF="http://www.valentineone.com/home.asp" target="_blank">Valentine V1</A>, <A HREF="http://www.ssiamerica.com/products/neo35/index.shtml" target="_blank">Neo Car MP3 player</A>, <A HREF="http://www.tirerack.com/accessories/smartire/smartire2.jsp" target="_blank">SmarTire wireless tire pressure monitoring</A>, ML430 winter rims with Dunlop WS M2 tires (255/60R17), <A HREF="http://www.benzworld.org/forums/forums/thread-view.asp?tid=45318&posts=20" target="_blank">crossdrilled/slotted/frozen/nickel plated rotors</A>, <A HREF="http://www.benzworld.org/forums/forums/thread-view.asp?tid=61783&posts=20">Autobahn mirror, rear fresnel lens</A>, <A HREF="http://www.benzworld.org/forums/forums/thread-view.asp?tid=69466&posts=20">SnowBear Utility Trailer</A>, <A HREF="http://www.escortradar.com/gtimer.htm">Escort GTimer GT2</A>, silver/polished <a href="http://www.hrewheels.com">HRE</a> <a href="http://images2.hrewheels.com/wheels/images/enlarge/enlarge-645r.jpg">645R</A> 20x9.5 <A href="http://www.wheelboutique.com">rims</A> with matching 295/40ZR20 <A HREF="http://www.tirerack.com/tires/tires.jsp?tireMake=Dunlop&tireModel=SP+Sport+9000& partnum=94ZR09000">Dunlop SP9000s</A>, <A HREF="http://www.kleemann.dk/tuning/index.htm">Kleemann Supercharger and ECU upgrade (550HP and 502 ft-lbs!)</A>. </small><center><HR>BMW is "Wanted, Mercedes Benz" backwards.<br><a href="http://www.benzworld.org/forums/view-profile.asp?action=view&uid=1044">tcp_ML500</a> says: Jeff's ML55K blows but BenzWorld doesn't!</center>
jdbower is offline   Reply With Quote
Old 05-12-2004, 01:47 PM   #8 (permalink)
wickedml's Avatar
sounds good to me. thanks jdbower.[8D]
