Old 05-07-2004, 09:28 PM   #1 (permalink)
maneesh's Avatar
Vehicle: 2002 ML 320
passenger door getting stuck while opening
Hi,
I recently noticed that the driver side passenger door gets stuck while opening. It eventually opens, and subsequent openings are normal. But after a few hours, the door opens a bit, then there's resistance, but after some additional force, it opens again.
Has this happened to anyone? Is it a case of applying some WD40? Will take it to the dealer when I get a chance but am wondering if this has happened to anyone else.
Thanks,
maneesh
2002 ML320: MB DVD Naviagtion, WeatherTech bug deflector, Benevento Sunroof Wind deflector, ML500 Grill, Schatz Chrome Shells, Drew's Chrome strip, door handle wood inserts.
maneesh is offline   Reply With Quote
Old 05-07-2004, 09:39 PM   #2 (permalink)
Where's my auto-leveling?
AndyFracica's Avatar
Date registered: Sep 2003
Vehicle: '06 ML350 '03 E320
RE: passenger door getting stuck while opening
maneesh - 5/7/2004 10:28 PM
Hi,
Thanks,
maneesh
Sounds like it needs some lubrication.
Andy
2006 ML350
723 - Pewter, 104 - Macadamia Interior, H04 - Brown Birds Eye Maple Wood, 167 Standard Non-Sport Pkg, 317 Comfort Pkg, 318 - Trim Package, 319 - Lighting Package, 320 - Entertainment Pkg, 324 - Sunroof Pkg, 580 - Std. Climate Control, 873 - Heated Front Seats, 890 - Power Liftgate, Navigation System, iPod interface kit
Modifications:
Added: Chrome Door handle cups, MB Twin Spoke 5-Spoke 18" wheels and tires
AndyFracica is offline   Reply With Quote
Old 05-08-2004, 01:45 PM   #3 (permalink)
sthu's Avatar
Vehicle: W163/W115
Send a message via Yahoo to sthu
Look at the big rubber molding (weather molding) that goes around the door opening. Especially at the section by the rear seats below the door lock/catch mechanism. Sometimes that part of the moldling come out from the groove and grab the door.
If that is the case, obvious answer is push it back in and if that is difficult, you can use putty knife (or something flat like CC) to guide the rubber molding. You may have to loosen the inside/trunk plastic panels by the door.
"de gustibus non est disputandem" ~ No accounting for taste
W163, W115, Matrix
1996 115lb Yellow Lab
sthu is offline   Reply With Quote
Old 05-11-2004, 12:23 PM   #4 (permalink)
maneesh's Avatar
door is now completly stuck
my wife told me today that she can't even open the door now. She had someone else who is stronger try to open the door and he was not able to open the door either - it was unlocked off course.
any thoughts as to what caused the door to get stuck?
Thanks,
maneesh
Old 05-11-2004, 12:34 PM   #5 (permalink)
JimB's Avatar
Date registered: Jul 2002
Vehicle: ML320/C320 Sprt
RE: door is now completly stuck
have the dealer check it, its a warranty issue. I know to drop it off and have a loanner is a pain[:(]
2000 ML320 Black Opal
2003 C320 Sport Sedan Bordeaux Red
1996 Honda Civic...
1991 Black Nissan Truck
2005 Honda CR-V EX AWD...New Add on to my Toys...
Trek, Full Suspension Mt. Bike
and a Dog, name Abby;-)
"Life is Short, Let's Enjoy It"
JimB is offline   Reply With Quote
Old 05-11-2004, 01:29 PM   #6 (permalink)
UncAl's Avatar
Date registered: Sep 2002
Vehicle: '08 Acura MDX
Is the inside door panel loose?
_______________
'08 Acura MDX w/ Tech package
Previously - '98 ML320 - 285k miles in 7 years
UncAl is offline   Reply With Quote
Old 05-11-2004, 02:32 PM   #7 (permalink)
tcp_ML500's Avatar
Irrelevant! If the door is unstuck while not opening it, don't open it and voila!
Seal Clubbing Champion '95 '97 '98 '01
Proud member of PETA, People for the Edible Treatment of Animals
Amateur Gynecologist & Cunning Linguist
tcp_ML500 is offline   Reply With Quote
Old 05-11-2004, 07:08 PM   #8 (permalink)
sthu's Avatar
Vehicle: W163/W115
Did you check the rubber molding like I said?
Molding would come out loose, get pinch between door and frame and grab the door.
Old 05-11-2004, 07:15 PM   #9 (permalink)
maneesh's Avatar
RE: Did you check the rubber molding like I said?
Took a look at it today...
It is not the molding - it is still in tact. The inside panel has come lose however. There are these white nylon screws that hold the inside panel to the door. These have broken and have come off.
So am taking it to the dealer to get it fixed. I have a feeling that they did not put it together properly after replacing the crappy rubber gasket around the windows.
On a side note, I jut realized how easy it is to remove the inside door panel.
Old 05-11-2004, 07:35 PM   #10 (permalink)
UncAl's Avatar
Ah! Same thing happened to me!
While a few clips were broken, the real problem was the fastners the clips go into. They are hot-glued to the inside of the door panel. So, we "re-hot-glued" them back!
Did you notice how cheaply-made the (inside of the)door panel is?
