Old 04-21-2004, 12:33 PM   #1 (permalink)
Date registered: Dec 2003
Vehicle: 2000ML320 ,2002Ml500
new rear shocks and springs
I recently changed the rear shock's put one from beinstein
and one of my car spring was broken so replaced both of them with the H and R springs
after that
the ride is great
you can feel the diffrence
cost rear springs both of them $166
Shocks from Beinstein $151 each
Total Labour hours :- 5 Hrs as the spring and the small scres were too complicated
but other then that everything went ok
oh ya add 2 hours just to figure out how to remove rear shocks
gary1378 is offline   Reply With Quote
Old 04-21-2004, 03:55 PM   #2 (permalink)
pointman's Avatar
Date registered: Sep 2003
RE: new rear shocks and springs
hi, did you have to remove the trunk liner to get to the shocks to remove?
pointman is offline   Reply With Quote
Old 04-21-2004, 03:58 PM   #3 (permalink)
i did not remove the trunk liner
you just take out the wheel well plastic and access the top from there with your hand
there is a small cap which has to be removed first
then you will see 3 screws which has to be taken out
the small cap can be removed by twisting
Old 04-21-2004, 10:16 PM   #4 (permalink)
pointman's Avatar
i thought so!!! when i had my ml lowered by an independent shop(my usual guy closed) he removed the entire trunk liner!!! i thought he was definitely going about it the hardway...thanks.
Old 04-21-2004, 10:20 PM   #5 (permalink)
AC_ML's Avatar
Vehicle: Black 2005 ML 500
My mechanic raised the ML to about the shoulder level and did not need to take any
My mechanic raised the ML to about the shoulder level and did not need to take any liner or plastic..
Though, without the right size wrench, it was a painful slow process to take the 3 nuts from the top rear shocks..
AC
2005 ML 500
Black, 18" AMG Wheels, 285/60R18 Falken Ziex ST/Z + Bi-Xenons(+ Drew's e-code mod), Yakima roof bars. Former vehicle 2001 ML 320 with 108K miles, when traded, and a large repair/defect history. After 3 years of owning my current 2005 ML 500, it has become another unreiliable vehicle with a very large/expensive repair/defect history..
AC_ML is offline   Reply With Quote
