Old 04-21-2004, 08:16 AM   #11 (permalink)
dfskinner's Avatar
Date registered: May 2003
Vehicle: 1999 ML430
RE: Do it yourself oil change..
I installed one of these on all my vehicles, works great, no mess, no fuss. You can probably purchase it at the local auto parts store.
http://www.partsamerica.com/PartDetails.asp?SourceArea=&SourcePage=SEARCHRESUL TS&MfrCode=FRA&MfrPartNumber=SD1&CategoryCode=312 6
Dennis
If you don't know where you want to go....
"Then it doesn't much matter how you get there"
1999 ML430
1998 Toyota Tacoma
1996 BMW 318is
2006 Mazada 5
2006 Infinity FX35
dfskinner is offline   Reply With Quote
Old 04-21-2004, 09:30 AM   #12 (permalink)
ae86pwr's Avatar
Date registered: Nov 2003
Vehicle: 98 ML320 / 06 S2000
Send a message via AIM to ae86pwr Send a message via MSN to ae86pwr
Brett - 4/22/2004 7:12 PM
Everyone has made viable points. I prefer to change the oil the old fashion way - from the oil pan drain.
For some reason MB has made this task difficult, when removing the plug the oil comes out at such an angle that it contacts steering components and makes a mess.
Anyone have any enlightening suggestions as to how one could make this more pleasant?
Brett
I cut the bottom off the .5L water bottles and angle + duct tape them together to slip it between the frame and the two hoses so it is long enough to reach the drain pan. after the drain. I use the bottle as funnel for oil filler hole
Denis
ae86pwr is offline   Reply With Quote
Old 04-21-2004, 12:14 PM   #13 (permalink)
azinn's Avatar
Date registered: Apr 2003
Vehicle: 2000 ML 430, 2007 Scion tC
Brett - 4/21/2004 10:12 AM
Brett
I've had pretty good luck with one of these http://www.fumotovalve.com/ Get the one with the nipple and you can drain it with a 1/4 inch hose into a drain pan [;)]
azinn is offline   Reply With Quote
Old 04-21-2004, 12:50 PM   #14 (permalink)
JimB's Avatar
Date registered: Jul 2002
Vehicle: ML320/C320 Sprt
azinn, which type will fit to ML? TY
2000 ML320 Black Opal
2003 C320 Sport Sedan Bordeaux Red
1996 Honda Civic...
1991 Black Nissan Truck
2005 Honda CR-V EX AWD...New Add on to my Toys...
Trek, Full Suspension Mt. Bike
and a Dog, name Abby;-)
"Life is Short, Let's Enjoy It"
JimB is offline   Reply With Quote
Old 04-21-2004, 02:18 PM   #15 (permalink)
azinn's Avatar
RE: azinn, which type will fit to ML? TY
JimB - 4/21/2004 2:50 PM
I've got the F-106N (N for nipple) with the ADP-106 adapter. The the drain valve screws into the adapter which screws into the oil pan. The adapter compensates for the recess in the oil pan. [:)]
Old 04-21-2004, 03:14 PM   #16 (permalink)
JimB's Avatar
Azinn,Thank a bunch, [:)]
Old 04-21-2004, 09:12 PM   #17 (permalink)
Date registered: Apr 2004
Send a message via MSN to late1
[:D] Right on!
late1 is offline   Reply With Quote
