I was wondering if anyone has attempted to remove the orange plastic insert in the 1998-2001 M-Class headlights. It is there so that the front turning signals reflect more with it, but I want to change the orange bulb to blue and it looks retarted with the insert in there. I know it is possible but am curious to know if it looks good, or if there is an easier way. Already have the side and rear blinker blue. thanks a lot
RE: Has anyone changed their front turning signals
550058 - 4/19/2004 8:39 AM
Welcome to Benzworld.
I'm going to assume that you are in the US because of the question. In the US the DOT requires a vehicle to have the amber color on the front corners of the vehichle.
The amber reflector is glued to the headlight assembly. You might damage the assembly trying to remove it. However, if you do choose to remove it you might have trouble getting yoiur vehicle inspected if your state has vehicle inspections. Worse yet you could receive a fine from the police if pulled over for some infraction.
The Euro-light assemblies may work but you will have to use the use turn signal lamp socket as the US uses a two filliment bulb where the Europeans use a single flash only turn signal.
I hope this helps.
Andy
2006 ML350
723 - Pewter, 104 - Macadamia Interior, H04 - Brown Birds Eye Maple Wood, 167 Standard Non-Sport Pkg, 317 Comfort Pkg, 318 - Trim Package, 319 - Lighting Package, 320 - Entertainment Pkg, 324 - Sunroof Pkg, 580 - Std. Climate Control, 873 - Heated Front Seats, 890 - Power Liftgate, Navigation System, iPod interface kit
Modifications:
Added: Chrome Door handle cups, MB Twin Spoke 5-Spoke 18" wheels and tires
550058 - 4/19/2004 9:39 AM
remove all the bulbs and ballasts, bake your lamps at 325 degress in the oven for about 10 minutes, check if the glue between the seems are loose, if not bake them for another 5 minutes.. once they become loose, pry the lens and housing apart with a screw driver.. then remove the amber lens!
buy some good silicon sealant and seal the lamp back together..
personally, i would just leave it alone.. i baked my freinds civic headlamps, worked fine. but that lamp was cheap and easy to replace if you screw up =)
JASON
2004 Porsche Carrera 4S
2003 Mercedes Benz S55 ///AMG
2000 Mercedes Benz ML55 ///AMG
fuk, i want to do the same thing but scared of screwin things up...i changed all my blubs to PIAA xtreme whites, even though the front orange 'retarded' reflector is still there...
*SOLD*'01 ML55: Bose system, Xtreme White Piaa Bulbs(Front, Side, Back, Fogs), White Neon StreetGlow, '03 ML55 Grille, '03 ML Chrome Tailgate Handle Cover, AMG ML Rear Spoiler, AMG Liscence Plate Covers, 1 JL Audio 12w6v2 w/ JL Audio 500/1 Amp
Check out my car at www.cardomain.com/id/mercedeschink*SOLD*
'04 PUMAs
Mohammad- did u buy those lights or did u take the orange insert out yourself? If you bought them, could you tell me where you got them from and how much they cost you... They look really sharp and I am planning to do they same to a white ML as well...Thanks a lot
since hes from kuwait, i assume hes driving a euro model with white reflectors... im gonna bake mine and paint the reflector parts silver. shouldnt be that hard.
