» Site Navigation
» Other Sites
Old 04-09-2004, 06:29 AM   #1 (permalink)
jojo's Avatar
Date registered: Jan 2003
Vehicle: 2001 430
looking for 20' wheels
hi.
I am looking for 20 inch wheels. (prefer silver/polished but not sure yet)
any suggestion, picture or wheels for sale?
Thank you.
jojo is offline   Reply With Quote
Old 04-09-2004, 06:41 AM   #2 (permalink)
Vehicle: 2002 ML55K
Send a message via AIM to jdbower Send a message via MSN to jdbower
RE: looking for 20' wheels
As a website sponsor you should probably hit www.tirerack.com, but their wheel selection is a little on the light side (although I do recommend them for tires). You can check out www.wheelboutique.com for a much better selection. I'm partial to silver over chrome and HREs, myself. May I recommend Dunlop SP9000s in 295/45R20 to match?
Thanks,
Jeff
2002 ML55 (debadged), Metallic Black Rear Star, 2003 DVD Navigation, fire extinguisher, OEM trailer hitch, OEM Smoke Hood Deflector, OEM Smoke Sunroof Deflector, OEM basic carrier, v60, VES, CD Changer, LED rear wing, LED brakes and rear turn signals, DesignTech halogen backup bulbs, amber ambiant passenger footwell lighting, Valentine V1, Neo Car MP3 player, SmarTire wireless tire pressure monitoring, ML430 winter rims with Dunlop WS M2 tires (255/60R17), crossdrilled/slotted/frozen/nickel plated rotors, Autobahn mirror, rear fresnel lens, SnowBear Utility Trailer, Escort GTimer GT2, silver/polished HRE 645R 20x9.5 rims with matching 295/40ZR20 Dunlop SP9000s, Kleemann Supercharger and ECU upgrade (550HP and 502 ft-lbs!).
BMW is "Wanted, Mercedes Benz" backwards.
tcp_ML500 says: Jeff's ML55K blows but BenzWorld doesn't!
jdbower is offline   Reply With Quote
Old 04-09-2004, 10:25 AM   #3 (permalink)
Date registered: Sep 2003
Vehicle: ML 320
Another trick that you can use is to search for wheels for the S class. While the wheels usually don't carry the same wieght rating, I don't think it will be a problem unless you are going off-road, carry heavy loads, or towing. Perhaps others with more knowledge could address this issue. Nevertheless, if you go to tirerack and search for S-class wheels, you will get significantly more options.
RickT is offline   Reply With Quote
Old 04-09-2004, 02:21 PM   #4 (permalink)
jojo's Avatar
Vehicle: 2001 430
jdbower - 4/9/2004 9:41 AM
That is great website. Do you have 295/45/20 for front and rear?
RickT - 4/9/2004 1:25 PM
I will try that. Will 2001 s430 be OK?
Old 04-09-2004, 03:43 PM   #5 (permalink)
Where's my auto-leveling?
AndyFracica's Avatar
Vehicle: '06 ML350 '03 E320
RickT - 4/9/2004 12:25 PM
Personally I would avoid buying wheels for the ML that do not have the proper load rating. For normal driving it might never be a problem, but in an emergency situation you would hate to have a wheel collapse and cause a wreck.
Andy
2006 ML350
723 - Pewter, 104 - Macadamia Interior, H04 - Brown Birds Eye Maple Wood, 167 Standard Non-Sport Pkg, 317 Comfort Pkg, 318 - Trim Package, 319 - Lighting Package, 320 - Entertainment Pkg, 324 - Sunroof Pkg, 580 - Std. Climate Control, 873 - Heated Front Seats, 890 - Power Liftgate, Navigation System, iPod interface kit
Modifications:
Added: Chrome Door handle cups, MB Twin Spoke 5-Spoke 18" wheels and tires
AndyFracica is offline   Reply With Quote
Old 04-09-2004, 04:36 PM   #6 (permalink)
Vehicle: 2002 ML55K
You should always use the same size wheels and tires for fronts and rears in the ML (or any AWD vehicle).
Old 04-09-2004, 06:15 PM   #7 (permalink)
MHPHOCKEY's Avatar
Date registered: Oct 2002
Vehicle: 2008 Mini Cooper S
Send a message via AIM to MHPHOCKEY
mine are for sale. i haev 20" armano 04 with zr rated 295 goodyear tires. make me an offer. no scratches. wheels are flawless, chrome, and have custom mercedes centercaps. the tires have tread.
mike
mhphockey@aol.com
MHPHOCKEY is offline   Reply With Quote
Old 04-09-2004, 11:27 PM   #8 (permalink)
Vehicle: ML 320
AndyFracica - 4/9/2004 6:43 PM
I was thinking the same thing until someone pointed out to me that the ML and S are about the same weight. They suggested that the wheels would perform the same with either vehicle in an emergency situation. The big difference is that you are not likely to put 1,340 pounds in the trunk of a S Class and drive it around.
The second thing that they pointed out is that many aftermarket wheels that say they are for the ML do not meet the load rating of the OEM wheels. So, even if you find a wheel that is "supposed to be for an ML", it still may not have the load rating.
The third reason they focused on the S Class is because the S Class wheels have a larger offset than the other MB vehicles and thus offer a better/proper fitment to the ML.
I am certainly not the expert here, just passing alone what someone else told me. Personally, I like the AMG wheels that Andy got because they offer the best (closest to OEM) offset that I have found (and they meet the load rating).[:)]
Old 04-10-2004, 12:41 PM   #9 (permalink)
RickT - 4/10/2004 1:27 AM
I went through this same exercise 6 months ago. Pretty much did the same research an discovered the the offset was significantly less on the S class. I wound up going with the AMG 18" wheels for my ML.
If you really want the correct wheels you should look at Brabus, and Lorinser wheels. I believe that these are the proper load rating for the ML but they are pricey.
As always, it is your decision.
Old 04-10-2004, 09:38 PM   #10 (permalink)
Wolfgang's Avatar
Vehicle: MBs
Here's a nice table listing offsets for various MB, Andy. Just found it on the Carlson server. [:D]
http://www.carlsson.de/de/raeder/uebersicht.html
Wolfgang is offline   Reply With Quote
