hi,
how to replace the bulb for the rear tailight brakelight. do you have to remove the rear panel to access the bulb? or take out the lens/light assembly from outside? if so how many bolts holding the tailight assembly? i can only see 2 bolts when i open the trunk.
The two bolts on the inside of the light assembly are removed and then the assembly is carefully pulled straight back. The outside of the assembly has two plastic nubs that fit into rubber rings in the body. They will break of if you are not careful.
When i did mine, I put a small amount of silicone grease on the rubber ring to facilitate removal in the future.
hi,
thank you,
RL
The instructions are all there. My only major tip, aside from what howard suggested, is to use a 10mm socket instead of a slotted screwdriver to remove the two plastic bolts. If you use the screwdriver, it is very easy to warp the plastic.
And yes, you remove the entire lens assembly to replace the bulbs.
Good luck!
<b><u>BenzWorld.org Senior Forum Host & Lighting guru</u></b>
<font face="arial"><font size="1"><a href="http://forums.benzworld.org/publications/pub.asp?id=67">MB OEM Bi-Xenons with E-code modification</a>, <a href="http://www.stongard.com/sgcontent/what_sgl.asp">custom-cut StonGard Light protection film</a>, Hella FF100 & FF200 foglamps with wireless switch, <a href="http://www.benzworld.org/forums/messages.asp?messno=81251&id=21&view=t">Hella dual tone air horns</a>, Bosch ParkPilot reverse warning system, Tomar Hide-a-way emergency vehicle front strobes, <a href="http://www.benzworld.org/forums/messages.asp?messno=58388&id=21&view=t">integrated reverse warning strobe lights with wireless switch</a>, <a href="http://forums.benzworld.org/forums/messages.asp?messno=40641&id=21&view=t">chrome handle accent strips and chrome door handle shells</a>, <a href="http://forums.benzworld.org/forums/messages.asp?messno=40351&id=21">AMG chrome ringed gauges</a>, <a href="http://www.benzworld.org/forums/messages.asp?messno=62376&id=21">Euro M-class footwell net</a>, <a href="http://www.http://www.benzworld.org/forums/messages.asp?messno=47347&id=21&view=t">3M reverse safety fresnel lens</a>, <a href="http://forums.benzworld.org/forums/messages.asp?messno=46855&id=21">Euro blindspot interior mirrors</a>, <a href="http://www.benzworld.org/forums/messages.asp?messno=54107&id=21&view=t">MCS GPS nav system</a>, chrome headlamp rings, chrome fender signal rings, <a href="http://www.mbworld.org/upload/2002/ml_int2.jpg">Personalised <i>designo</i> interior</a>, <a href="http://forums.benzworld.org/gallery/showlink.asp?parentid=32&catid=328&subname=Andrew` s_M-class">Drinkholders.com burl walnut ML cupholder</a>, <a href="http://www.benzworld.org/forums/forums/thread-view.asp?tid=1164344&posts=29">hardwired Valentine One radar detector</a>, <a href="http://forums.benzworld.org/forums/messages.asp?messno=43386&id=21">LED-based front and rear LED footwell ambience lighting</a>, <a href="http://www.benzworld.org/forums/messages.asp?messno=64477&id=21">illuminated MB door sills for each door</a>, <a href=http://www.*************.com/mb_results.asp?model=W163&class=m-class&category=Aerodynamics%3A+Roof+Wings+and+Bug+ Deflectors">Clear acrylic hood deflector</a>, Weathertech window deflectors, EGR rear deflector, 3M Scotchtint 50% tint on front windows, <a href="http://www.benzworld.org/news/extimages/48000kms/5.jpg">3M Scotchtint 20% tint on top 4" of windshield</a>, <a href="http://www.benzworld.org/gallery/pics/32832371212200211007AM.jpg">driver side mounted fire extinguisher</a>, <a href="http://www.*************.com/mb_results.asp?model=W163&class=m-class&category=Chrome+Tailgate+Handle">chrome tailgate handle</a>, "Elegance" side badges, <a href="http://www.*************.com/mb_results.asp?model=W163&class=m-class&category=Bose+Tweeters%2FSail+Panels">'02 Bose tweeters and sail panels</a>, <a href="http://www.benzworld.org/forums/messages.asp?messno=37287&id=21&view=t">'02+ tailgate filler panel</a>, <a href="http://www.*************.com/mb_results.asp?model=W163&class=m-class&category=Bumper+Grilles">AMG silver painted/chrome accented front grill, silver painted lower bumper grill</a>, MB OEM Style 1 chrome sidesteps & chrome brushguard with skidplate, MB OEM front mudflaps & <a href="http://www.benzworld.org/gallery/showlink.asp?page=11&order=id&CatID=328&parentid=3 2&parentname=&subname=Andrew%60s_M-class">aftermarket flexible rear mudflaps</a>, <a href="http://www.benzworld.org/news/extimages/48000kms/6.jpg">chrome door rubstrips</a>, <a href="http://www.benzworld.org/forums/messages.asp?id=21&messno=79983&view=t">MB Lamella Skyview roof deflector</a>, <a href="http://www.benzworld.org/news/extimages/48000kms/10.jpg">MB accessory roof crossbars & ski rack</a>, <a href="http://www.*************.com/mb_results.asp?model=W163&class=m-class&category=Exhaust+Tip">AMG oval exhaust tip</a>, <a href="http://www.benzworld.org/forums/messages.asp?messno=62611&id=21&view=t">17" EVO II Sport package wheels & Michelin Cross Terrains</a>, DesignTech halogen backup bulbs, <a href="http://www.*************.com/mb_results.asp?model=W163&class=m-class&category=LED+Brake+Lights">Formymercedes.com 20" LED brake strip with Flash alert</a>, 6" 3rd brake lamp LED strip, <a href="http://www.*************.com/mb_results_m.asp?model=W163&class=m-class&category=LED+Replacement+Bulbs">High-intensity LED taillamps, front and rear LED amber turn signals</a>, <a href="http://forums.benzworld.org/forums/messages.asp?messno=49436&id=21&view=t">HyperWhite LED city lamps</a></font></font>
after taking out the 2 bolts i cant pull the tailight assembly backward. it seems that the front side of the lens (in my case the part that is close to the fuel door)get stuck. i dont want to pull it by force. is there any trick to pullback the tail light smoothly?
