» Site Navigation » Other Sites
» Network Links
03-24-2004, 07:01 PM
#1 (permalink )
Date registered: Jul 2003
Vehicle: Audi A4
Weapon R Dragon Intakes
I was looking at Weapon R Dragon Intakes on
http://www.prostreetonline.com/pso/p...uctsku=808-113 and i was wondering if they are any good for an ML 320
03-24-2004, 08:34 PM
#2 (permalink )
Vehicle: 2002 ML55K
RE: Weapon R Dragon Intakes
As mentioned before, they're really just for looks. As far as the sound is concerned, it won't change the exhaust much but as someone mentioned you may be able to hear a difference in the driver's seat (even my blower sounds normal from the outside, but I can hear it rev up on startup and howl nicely under "spirited" acceleration). You'll also want to watch out because a new intake will void a lot of your engine warranty.
If the above doesn't dissuade you I think some people have tried WeaponR stuff and other than mixing rice and kraut they physically fit in an ML.
Thanks,
Jeff
<hr><small>2002 ML55 (debadged), <A HREF="http://www.benzworld.org/forums/forums/thread-view.asp?tid=46299&posts=20" target="_blank">Metallic Black Rear Star</A>, 2003 DVD Navigation, fire extinguisher, OEM trailer hitch, OEM Smoke Hood Deflector, OEM Smoke Sunroof Deflector, OEM basic carrier, v60, VES, CD Changer, <A HREF="http://www.*************.com/contsp/product.asp?intProdID=D-ML163-LED-Painted&model=W163&category=LED+Brake+Lights+" target="_blank">LED rear wing</A>, <A HREF="http://www.*************.com/mb_results_m.asp?model=W163&class=m-class&category=LED+Replacement+Bulbs" target="_blank">LED brakes and rear turn signals</A>, <A HREF="https://www.designtech-intl.com/merchant.ihtml?pid=47&lastcatid=12&step=4" target="_blank">DesignTech halogen backup bulbs</A>, <A HREF="http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&category%5Fname=CT LG%5F010%5F012%5F011%5F000&product%5Fid=276%2D272" target="_blank">amber ambiant passenger footwell lighting</A>, <A HREF="http://www.valentineone.com/home.asp" target="_blank">Valentine V1</A>, <A HREF="http://www.ssiamerica.com/products/neo35/index.shtml" target="_blank">Neo Car MP3 player</A>, <A HREF="http://www.tirerack.com/accessories/smartire/smartire2.jsp" target="_blank">SmarTire wireless tire pressure monitoring</A>, ML430 winter rims with Dunlop WS M2 tires (255/60R17), <A HREF="http://www.benzworld.org/forums/forums/thread-view.asp?tid=45318&posts=20" target="_blank">crossdrilled/slotted/frozen/nickel plated rotors</A>, <A HREF="http://www.benzworld.org/forums/forums/thread-view.asp?tid=61783&posts=20">Autobahn mirror, rear fresnel lens</A>, <A HREF="http://www.benzworld.org/forums/forums/thread-view.asp?tid=69466&posts=20">SnowBear Utility Trailer</A>, <A HREF="http://www.escortradar.com/gtimer.htm">Escort GTimer GT2</A>, silver/polished <a href="http://www.hrewheels.com">HRE</a> <a href="http://images2.hrewheels.com/wheels/images/enlarge/enlarge-645r.jpg">645R</A> 20x9.5 <A href="http://www.wheelboutique.com">rims</A> with matching 295/40ZR20 <A HREF="http://www.tirerack.com/tires/tires.jsp?tireMake=Dunlop&tireModel=SP+Sport+9000& partnum=94ZR09000">Dunlop SP9000s</A>, <A HREF="http://www.kleemann.dk/tuning/index.htm">Kleemann Supercharger and ECU upgrade (550HP and 502 ft-lbs!)</A>. </small><center><HR>BMW is "Wanted, Mercedes Benz" backwards.<br><a href="http://www.benzworld.org/forums/view-profile.asp?action=view&uid=1044">tcp_ML500</a> says: Jeff's ML55K blows but BenzWorld doesn't!</center>
03-24-2004, 08:36 PM
#3 (permalink )
Date registered: Mar 2004
Vehicle: 99 ML430
Holy god that thing is hideous.. I was thinking it would be cool to hook up an ML55 dual air box set-up on a 430.. A nice simple K&N open ended set-up would look sweet and sound better..
03-24-2004, 08:39 PM
#4 (permalink )
Vehicle: 2002 ML55K
Sorry, ML55 only has one airbox as far as I can tell... I'm surprised I don't see that in more mods lists (ML320 with ML55 intake upgrade).
03-24-2004, 08:41 PM
#5 (permalink )
Vehicle: 99 ML430
jdbower - 3/24/2004 10:39 PM
But.. But.. but.. I coulda sworn..
Oh well... color me corrected.. Thanks bruddah..
03-24-2004, 08:46 PM
#6 (permalink )
Date registered: Nov 2003
Vehicle: 98 ML320 / 06 S2000
All Show no Go.
Weapon R is not even preferred by Honda boys.
The minute you put on this crappy foam filter. Thats when you see your oil turns dirty very very fast. Also Cone filter doesn't make your car go any faster because your N/A engine can only "suck" air to a limit. Since this cone filter is placed behind the radiator then your intake will only breathe in HOT air. The ML stock intake has two inlets of COLD air and thats plenty engine. If you like to float air better. Just use the good ole' K&N drop-ins, they will not mess up your MAF sensor unless you over oiled it. Our M112 engine has the long intake runners which bascially render your "CAI" useless ... unless you drive at 4000 rpm all day long.
Save that money and buy yourself some Dynamat Door kit and you might bet more utility from it.
just my 2 cents
03-24-2004, 08:56 PM
#7 (permalink )
Vehicle: Audi A4
what kind of K&N filter is it
03-24-2004, 09:17 PM
#8 (permalink )
Read about it here
http://knfilters.com/filtercharger.htm
Part number: 33-2703
You can probably order these in lots of places online
I've got mine from http://www.performanceintl.com/
I have been running on K&N filter since 1998 and I've never had any problems with it
03-24-2004, 09:26 PM
#9 (permalink )
Read about it here
03-24-2004, 10:06 PM
#10 (permalink )
Date registered: Sep 2003
im not a fan of the drop in filters cause the airbox is still in the same spot... custom fabrication allows for bending of the new housing, and the cone to be set at a optimal angle for cool air.
Thread Tools Display Modes Linear Mode
