» Featured Product
» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W163 M-Class
Old 02-28-2004, 12:01 AM   #1 (permalink)
lon000007's Avatar
Date registered: Oct 2003
Vehicle: 1999 ML 430
temperature?
what temperature are you guys normal at ML (after warm up), i usually thinking my ML are too hot?[:(]
<img border="0" src="http://www.gtwheels.com/HTML/ML%20Full%20custom%20Trunk_logo%20535x75.jpg" width="535" height="75">
***Full custom trunk***
·Sony CDX-C90 CD Player
·Sony CDX-757 MX MP3 changer
·Precision Power PPI PCX-480 4 Channel Amplifier
·Precision Power PPI PCX-280 2-Channel Amplifier
·Rockford Fosgate CPCM10 1 farad Power Capacitor
·MB QUART QM 218.61Q 2-Way Components Crossovers
·MB QUART Midrange PWE 130
·2 NAKAMICHI 10" SUBWOOFER
***K&N Filtercharger air filter***
***Bosch Platinum+4 spark plugs***
***HELLA FF50 Driving Lamp***
lon000007 is offline   Reply With Quote
Old 02-28-2004, 05:48 PM   #2 (permalink)
Member
Drew's Avatar
Date registered: Jul 2002
Vehicle: '00 ML320 Elegance
RE: temperature?
lon000007 - 2/27/2004 12:01 AM
Mine usually runs about 85-90 degrees. This is pretty much the normal range.
Drew is offline   Reply With Quote
Old 02-28-2004, 07:40 PM   #3 (permalink)
Where's my auto-leveling?
AndyFracica's Avatar
Date registered: Sep 2003
Vehicle: '09 ML350, '03 E320, '99 E320 4Matic, '98 C280
RE: temperature?
lon000007 - 2/28/2004 2:01 AM
Mine is close to Drew's. It usually runs right at 82 unless it is very cold outside.
Andy
2009 ML350, Iridium Silver, Ash MB Tex
P2: Rear Cam, 115V Outlet, Parktronic, Pwr Seats w/ 4-Way Lumbar w/ Mem Pwr Folding Mirrors, Comand w/ Navi & Voice Control, HD Radio w/ Satellite, + iPod/MP3 Interface, Harman/Kardon, Keyless-Go, Pwr Liftgate
Lighting Pkg: Bi-Xenon Headlamps, LED Tail Lamps, Headlamp Washers
Extras: Hitch, Running Boards, Chrome Door Handle Inserts
Mods: Tinted front windows, Sports Pedals
AndyFracica is offline   Reply With Quote
Old 02-29-2004, 06:37 AM   #4 (permalink)
ekhalil's Avatar
Date registered: Nov 2003
Vehicle: 2003 ML500
Send a message via MSN to ekhalil
RE: temperature?
I used to have the temp between 85-90 (in hot summer), but recently I can see that the temp is going up to 95 although that the weather now is much colder than in summer. what can this be? is it something I have to report to the dealer?
2003 ML500 (Brilliant Silver, Charcoal Leather)
M2: Leather upholstery, additional wood interior trim, trip computer, automatic day/night driver-side and rear-view mirrors, power-folding outside mirrors w/memory, rain-sensing wipers, power front seats w/memory, locking under-passenger-seat compartment and rear privacy glass.
M4: Spare Tire Carrier
M5: Sunroof Package w/Power Rear Qtr Windows
M7: Two-passenger 3rd-row seat.
COMAND 2.0 with CD Changer
AMG Instrument Cluster (163 540 7811)
SonyEricsson HCB-30 Bluetooth Car kit
Megacomm Multimedia A/V Interface for COMAND 2.0
SONY DVX-100 DVD Changer
JVC 6.5" headrest wide color monitors (KV-MH6500)
ekhalil is offline   Reply With Quote
Old 02-29-2004, 10:23 AM   #5 (permalink)
RE: temperature?
ekhalil - 2/29/2004 8:37 AM
Check your radiator and condeser coil to see if they have become blocked with bugs or dirt.
Old 03-10-2004, 12:05 AM   #6 (permalink)
ekhalil's Avatar
Vehicle: 2003 ML500
RE: temperature?
AndyFracica - 3/1/2004 9:23 PM
I can't see anything strange in the radiator. where is the condenser coil located?
I checked the cooling water level and it was lower than the cold level mark, the dealer added distilled water but still the temp is at 95. the SA was telling me that this is a normal temperature, but I can't beleive it since my car used to have 85-90 degrees in summer. Anybody has a V8 (may be it's different[?] who can tell me what temperatures they use to have? Thanks[?]
Old 03-10-2004, 05:32 AM   #7 (permalink)
RE: temperature?
ekhalil - 3/10/2004 2:05 AM
ekhalil,
The condenser coil is in front of the radiator.
Check the fan clutch on the fan on the engine. If it goes bad it will not let the fan stop turning at highway speeds, thereby restricting air flow to through the radiator.
Water temp will vary by out door ambient temp but it should be the same as previously observed.
Another thought is that you could have a temp sensor going bad.
Old 03-10-2004, 06:10 AM   #8 (permalink)
ekhalil's Avatar
Vehicle: 2003 ML500
RE: temperature?
AndyFracica - 3/11/2004 4:32 PM
ekhalil,
Thanks Andy,
Does the 95 degrees indicate some malfunction, or just the change in temp which is bad? Actually my SA was convincing me that the higher temperature is better for the metal than the lower temperature [:D].
In the owners manual, it says that any temperature below 120 is normal. I'm just worried because the temp was lower when the ambient temp was around 45 degrees than now when the ambient temp is 20 [:(]
Old 03-10-2004, 06:32 AM   #9 (permalink)
tcp_ML500's Avatar
RE: Actually my SA was convincing me that the higher temperature is better
ekhalil - 3/10/2004 8:10 AM
Your engine will be more efficient when it has warmed up. The FSS actually monitors the number of cold starts and trips you have taken without reaching optimum oil temperature. Cold starts are not bad because the metal parts are cold, it's more due to the fact that the oil has not reached optimum temperature and thus does not provide it's best friction limiting characteristics. The engine has not been fully lubricated when you cold start. That's why you should take it easy for the first few miles...
So there is an optimum range of temperatures, and maintaining a coolant temp of 85-90 seems to be the ticket to keep oil temp and engine parts within check. Exceeding 120 Celcius for the coolant will most likely cause engine damage.
To say that higher temperatures are better is somewhat of an idiocy without context! If that were true, we should all get rid of our radiators so as to maximize the temperature. 95 is not worrysome, fluctuations are to be expected although I notice that I am usually in the 85-90 range myself.
Have you checked that the coolant level in the expansion vase (it's orange liquid and it is located centrally, closest to the windshield.
Have you added coolant in between your observations of the temps going up? If so, did you use the MB coolant and mixed 1:1 as prescribed by MB? The coolant has additives that will increase the solution's boiling point so you really want to follow instructions if you need to top off!
"tcp, Theoretically most arguments are circular. and yet if the basis is good....." -- aardvark
tcp_ML500 is offline   Reply With Quote
Old 03-11-2004, 01:05 PM   #10 (permalink)
ekhalil's Avatar
Vehicle: 2003 ML500
tcp_ML500 - 3/11/2004 5:32 PM
I've checked the water level and it's below the cold level sign. Where does the water go? Is it normal that water level drops?[?]
