How to remove the Radio - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 02-15-2004, 03:41 PM Thread Starter
ML_OWN's Avatar
Date registered: Dec 2003
Vehicle: ML320, ML430, E320
Send a message via MSN to ML_OWN
I just got my new radio and I was wondering how to remove the old one('98 ML320)??? I don't want to break anything just by trying to find how to by myself...
Thanks Guys !![8)]
Enjoy the sweet ride of your ML,
JS
ML_OWN is offline
post #2 of 9 (permalink) Old 02-15-2004, 04:38 PM
roadsession's Avatar
Date registered: Nov 2002
Vehicle: 99ML320 (retired) C230 530xi 911-C4
RE: How to remove the Radio
You can buy the radio removal keys from the dealer - it's only $3 or $4. Don't bother with ebay. It's cheaper at the dealer.
If you don't have the radio removal keys, then you can use the small blade of a swiss army knife. There are two small slits in the bottom sides of the radio where you insert the radio removal keys and then the radio removal keys have a ring you you pull on and voila everything comes out.
I would go to the dealer on Tue and use the radio removal keys so as to not mess up your radio.
Porsche Carrera 4 Cabriolet
BMW 530xi
MB W202 C230
MB W163 ML320 (SOLD)
roadsession is offline
post #3 of 9 (permalink) Old 02-15-2004, 05:58 PM
Vehicle: 2002 ML500
Thanks now I know how to remove the radio, but what I don't know is which wire is which, so that I can install an Amp. and Subs Can someone tell me? or where I can get a book. I have a 2002 ML with navigation
Sir Bentley is offline
post #4 of 9 (permalink) Old 02-15-2004, 07:12 PM Thread Starter
ML_OWN's Avatar
Thanks RoadSession! I'll take a look at this and give you some feedback.
JS
ML_OWN is offline
post #5 of 9 (permalink) Old 02-15-2004, 07:47 PM
Sir Bentley - 2/15/2004 7:58 PM
Do a search for wiring pin outs.
I remember someone already detailed this...
BMW 530xi
MB W202 C230
post #6 of 9 (permalink) Old 02-15-2004, 10:32 PM
CCORLEY's Avatar
Date registered: Jan 2004
Vehicle: 99' ML430, 95' E300D
If you have the Bose system and wish to keep the factory amp, you will need to install a High to Low power converter(do not install your new unit without one, you will smoke your Bose amp). You can purchase one at Wal-mart for about 13.00, found in the radio install section, Circuit City sells it for 40.00, they are identical. Basically what you are doing is converting your new high power radio unit to low power inputs into your amp. You will also need a wiring harness, I bought mine from Circuit City. It's a generic VW / Universal euro adapter cost of about 15.00. The wiring harness will make installation easy and will explain the wiring configuration. Good Luck!
CCORLEY is offline
post #7 of 9 (permalink) Old 02-16-2004, 08:42 PM
Vehicle: 2002 ML500
CCORLEY - 2/16/2004 12:32 AM
I'm not replacing the factory unit I just want to install an Amplifier to power my subwoofer. I did a search for wiring pin outs but that didn't help.
post #8 of 9 (permalink) Old 02-17-2004, 06:52 AM
Benza's Avatar
Vehicle: 2001 ML 55AMG
Quoted: 2 Post(s)
C1 - 16 Pin Â*(A and B)
Pin Color Description Notes
A01 Blue ESP/SPS/BAS control module
A02 Green Data link connector (DTC readout)
A03 Gray Backup lamps
A04 Red Battery (circuit 30) +12V constant on
A05 Orange FM/AM amplifier Standard radio
A05 Orange FM/AM amplifier Bose premium sound system
A06 White PWM dimming, instrument lights
A07 Pink Power (circuit 15) switched, ignition
A08 Brown Ground
B01 Red Right rear door speaker + Bose premium sound system
B01 Red Right rear door speaker + Standard radio
B02 Gray Right rear door speaker - Bose premium sound system
B02 Gray Right rear door speaker - Standard radio
B03 Orange Right front door speaker + Bose premium sound system
B03 Orange Right front door speaker + Standard radio
B04 White Right front door speaker - Bose premium sound system
Benza is offline
post #9 of 9 (permalink) Old 08-15-2004, 09:56 PM
Date registered: Nov 2003
Vehicle: 2000 ml320
Can someone help me out? I Can't get my pioneer 690 to work. I followed all the wiring diagram but there's no music coming out of the speakers. I used the high low converter and followed the directions precisely. One thing I am not sure of is where to splice the remote start from the pioneer to? an amp? any help? thanx
lukkyp is offline
