Old 02-13-2004, 11:00 AM   #1 (permalink)
Joyride's Avatar
Date registered: Jan 2004
Vehicle: 08 GL550, 02 E320, 97 S320, 84 380SEL, 70 280SE
Cold Air Intake for ML...
Hi Everybody,
came accross this Cold Air Intake System for the ML:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=38634&item=2459016 947
What do you guys think? Would you install it in your ML? States that it fits any ML. I have the 2003 ML 350. Will it fit? Does it void warranty? Any comments appreciated.
Thank you!
"Bitte ein Bit"
08 MB GL550
07 GMC Sierra Denali - SOLD
04 Yamaha YZF-R1
03 MB ML350 - SOLD
02 MB E320
97 MB S320
84 MB 380SEL
70 MB 280SE
Joyride is offline   Reply With Quote
Old 02-13-2004, 11:47 AM   #2 (permalink)
pointman's Avatar
Date registered: Sep 2003
RE: Cold Air Intake for ML...
ill sell you mine... almost brand new... custom fabricated for the ml...100.
pointman is offline   Reply With Quote
Old 02-13-2004, 01:12 PM   #3 (permalink)
Vehicle: 2002 ML55K
Send a message via AIM to jdbower Send a message via MSN to jdbower
If it fits any ML, yours should be OK (there is no difference in the airbox for any W163 - you've got the same setup as an ML55). It will void the warranty on the bulk of the engine issues you'll have (unless you've got a great relationship with your SA). I doubt you'll see much improvement through the upgrade - 10% seems like a random number with no basis in fact (I should call them on it, I'd love an extra 55HP!). Remember, if it were as simple as an extra $100 or so for significant gains with no detriments, MB would have already done it!
Thanks,
Jeff
<hr><small>2002 ML55 (debadged), <A HREF="http://www.benzworld.org/forums/forums/thread-view.asp?tid=46299&posts=20" target="_blank">Metallic Black Rear Star</A>, 2003 DVD Navigation, fire extinguisher, OEM trailer hitch, OEM Smoke Hood Deflector, OEM Smoke Sunroof Deflector, OEM basic carrier, v60, VES, CD Changer, <A HREF="http://www.*************.com/contsp/product.asp?intProdID=D-ML163-LED-Painted&model=W163&category=LED+Brake+Lights+" target="_blank">LED rear wing</A>, <A HREF="http://www.*************.com/mb_results_m.asp?model=W163&class=m-class&category=LED+Replacement+Bulbs" target="_blank">LED brakes and rear turn signals</A>, <A HREF="https://www.designtech-intl.com/merchant.ihtml?pid=47&lastcatid=12&step=4" target="_blank">DesignTech halogen backup bulbs</A>, <A HREF="http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&category%5Fname=CT LG%5F010%5F012%5F011%5F000&product%5Fid=276%2D272" target="_blank">amber ambiant passenger footwell lighting</A>, <A HREF="http://www.valentineone.com/home.asp" target="_blank">Valentine V1</A>, <A HREF="http://www.ssiamerica.com/products/neo35/index.shtml" target="_blank">Neo Car MP3 player</A>, <A HREF="http://www.tirerack.com/accessories/smartire/smartire2.jsp" target="_blank">SmarTire wireless tire pressure monitoring</A>, ML430 winter rims with Dunlop WS M2 tires (255/60R17), <A HREF="http://www.benzworld.org/forums/forums/thread-view.asp?tid=45318&posts=20" target="_blank">crossdrilled/slotted/frozen/nickel plated rotors</A>, <A HREF="http://www.benzworld.org/forums/forums/thread-view.asp?tid=61783&posts=20">Autobahn mirror, rear fresnel lens</A>, <A HREF="http://www.benzworld.org/forums/forums/thread-view.asp?tid=69466&posts=20">SnowBear Utility Trailer</A>, <A HREF="http://www.escortradar.com/gtimer.htm">Escort GTimer GT2</A>, silver/polished <a href="http://www.hrewheels.com">HRE</a> <a href="http://images2.hrewheels.com/wheels/images/enlarge/enlarge-645r.jpg">645R</A> 20x9.5 <A href="http://www.wheelboutique.com">rims</A> with matching 295/40ZR20 <A HREF="http://www.tirerack.com/tires/tires.jsp?tireMake=Dunlop&tireModel=SP+Sport+9000& partnum=94ZR09000">Dunlop SP9000s</A>, <A HREF="http://www.kleemann.dk/tuning/index.htm">Kleemann Supercharger and ECU upgrade (550HP and 502 ft-lbs!)</A>. </small><center><HR>BMW is "Wanted, Mercedes Benz" backwards.<br><a href="http://www.benzworld.org/forums/view-profile.asp?action=view&uid=1044">tcp_ML500</a> says: Jeff's ML55K blows but BenzWorld doesn't!</center>
jdbower is offline   Reply With Quote
Old 02-13-2004, 01:20 PM   #4 (permalink)
BenzWorld Post Whore
S4toML's Avatar
Date registered: Dec 2002
Vehicle: 05 C320 4MATIC
Take your $100 and use it to buy a PP rear spoiler. Your ML will look "faster" ;)
2005 C320 4MATIC | 2003 ML350 Inspiration Edition | 2001 Audi S4 Avant (Blk) - Stage II | 2001 Audi S4 Avant (Nogaro Blue) - Stage I | 2000 Audi S4 Sedan (Silver)
S4toML is offline   Reply With Quote
Old 02-13-2004, 01:24 PM   #5 (permalink)
Vehicle: 2002 ML55K
And you won't fishtail as much at high speeds :-)
Old 02-13-2004, 02:17 PM   #6 (permalink)
tcp_ML500's Avatar
Sounds like you have a problem with the open diffs [:D]
with the engine you have what should happen is that under max load your ML should not be able to move an inch, the wheels should be spinning so much that you'd never get any grip and you'd stay immobilized.
Try it, it should work!
If it doesn't, it's probably because the pavement is not perfectly flat under the wheels, or because your ML lacks power. If you do not turn ESP off and it wors as designed, the electronics should apply the brakes so the wheels won't spin, same result, immobilized, and a new set of pads and rotors!
I've said it before, your ML sucks <font color=white>a lot more air than mine</font>!
Seal Clubbing Champion '95 '97 '98 '01
Proud member of PETA, People for the Edible Treatment of Animals
Amateur Gynecologist & Cunning Linguist
tcp_ML500 is offline   Reply With Quote
Old 02-13-2004, 06:36 PM   #7 (permalink)
jdanish's Avatar
Vehicle: ML500, 2005
spend the money on something else, it does not help. will have MAF problems, no better economy or power.I have tried 4 different types including the Carbon Fiber box. worthless! K&N adds some milage,no difference in power. Many ECU codes, some MAF failures jd
jdanish- 2005 ML500
Independent Repair Shop Owner
ASE Master Technician, FAA Certified Flight Instructor
jdanish is offline   Reply With Quote
Old 02-13-2004, 06:42 PM   #8 (permalink)
jdanish's Avatar
One other point, as Jeff said, MB spent some time on the box, has two inlets and is designed for several engines. I cant believe anyone else would have spent the same amount of money and engineering on the air cleaner. jd
