» Featured Product
» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W163 M-Class
Old 02-03-2004, 08:14 PM   #1 (permalink)
Vehicle: ML430 - sold
ETS BAS warning light fix...
Usual legal disclaimer stuff…
You under take this repair at your own risk. The writer assumes absolutely no responsibility in anyway shape or form for any losses incurred while performing this fix.
With this in mind read on…..
If the pictures below aren't showing, then follow this link Brake Pedal Switch Goes Bad
If your BAS ETS warning light occasionally illuminates for no apparent reason, stays lit for a while then mysteriously resets itself, you most likely have a faulty brake pedal switch.
This is a fairly common ML problem and most MB dealers will likely stock the replacement switch, most recent part number as of Dec '06 is 001-545-64-09 and the cost is now something like $23.
Here's a picture of the offending part taken on a genuine ML floor mat.
Fortunately the part is inexpensive ($13 plus tax) and easy to replace.
Anyone who can handle a screwdriver and has ½ hour to spare should be able to perform this repair.
Now read on to save yourself a few bucks, fix the BAS ETS problem and have a closer look at the fine engineering of your ML (plastic accelerator pedal assembly excluded !)
Start by removing the cover which goes round the brake and accelerator pedals.
Do this by first removing the two large 1� diameter plastic nuts shown here.
I’ve found a large bladed flat screwdriver works well to rotate them anti-clockwise.
Having removed the plastic nuts, remove the two black screws shown here in these two pictures.
This picture was taken from a different angle.
Carefully pull the plastic cover away, but take care as the OBDII connector will still be attached.
For better access remove the OBDII connector from the cover by sliding the retaining latch to the right as shown here.
Set the plastic cover aside out of the way.
The brake switch can now be seen in position just above the brake pedal.
It is easily removed by depressing the tab and rotating it 90 degrees clockwise.
The switch should now be free and hanging by its leads.
Make a note of the connector locations and orientation then disconnect them both.
Discard the old switch (or save it for later examination !)
Re-connect the cables to the new switch taking care to orientate them correctly, the re-install the switch. Make sure the locating tab clicks securely into the bracket and that the cables are not snagged on anything.
Out of interest, take a close look at the accelerator pedal assembly – what a cheesy set-up. No wonder some owners complain of slack or wobble.
Also take a close look at the distance between the brake pedals resting point and how far it needs to travel before it starts to exert pressure on the brake master cylinder – hmmm interesting eh ?
Anyway, your nearly done !
Re-attached the OBDII connector to the cover by relocating the connector then sliding the latch back to the left. Make sure the OBDII connector is firmly fixed in place, then put the cover back in place.
I found it easiest to secure the cover in place by means of the 2 black screws first, the re-fasten the front in place with the black nuts.
Finally turn on the iginition and check that your brake lights work – hey you might even find you have an unrelated blown bulb !
Tim (Formerly a senior race engineer / designer at Cosworth Racing UK for Formula 1 and CART engines)
'00 ML430
Replaced with Lexus RX400h 4x4 (0 to 60MPH in 6.5 seconds and 30MPG city)
My other 4x4 '03 Colbalt Blue Porsche Stage III 996 Twin Turbo (60 to 130MPH in 8.7 seconds and 12 MPG)
2005 Mini Cooper S, a pocket rocket
2002 VW Beetle, daily hack
Past cars of note:
'02 Porsche 996
'99 Porsche Boxster
timf is offline   Reply With Quote
Old 02-04-2004, 07:08 AM   #2 (permalink)
BenzWorld Post Whore
S4toML's Avatar
Date registered: Dec 2002
Vehicle: 05 C320 4MATIC
Tim: Very nice publication! I will definitely save this for future tech reference.
2005 C320 4MATIC | 2003 ML350 Inspiration Edition | 2001 Audi S4 Avant (Blk) - Stage II | 2001 Audi S4 Avant (Nogaro Blue) - Stage I | 2000 Audi S4 Sedan (Silver)
S4toML is offline   Reply With Quote
Old 02-04-2004, 07:56 AM   #3 (permalink)
tcp_ML500's Avatar
Don't care what you say, you are liable! I followed your instructions on how to remove the
gas cap and look at my finger now!
Or, you could give me a ride in your 996 and I'll drop my legal action against you...
"tcp, Theoretically most arguments are circular. and yet if the basis is good....." -- aardvark
tcp_ML500 is offline   Reply With Quote
Old 02-04-2004, 08:05 AM   #4 (permalink)
JimB's Avatar
Date registered: Jul 2002
Vehicle: ML320/C320 Sprt
RE: ETS BAS warning light fix...
timf, Thanks a lot for sharing...very nice It will definately help us to save some money on labor[:)][;)]
Gracias
2000 ML320 Black Opal
2003 C320 Sport Sedan Bordeaux Red
1996 Honda Civic...
1991 Black Nissan Truck
2005 Honda CR-V EX AWD...New Add on to my Toys...
Trek, Full Suspension Mt. Bike
and a Dog, name Abby;-)
"Life is Short, Let's Enjoy It"
JimB is offline   Reply With Quote
Old 02-04-2004, 02:25 PM   #5 (permalink)
AC_ML's Avatar
Vehicle: Black 2005 ML 500
Great document on this common problem, and your instructions work perfectly, too, for fixing up
Great document on this common problem, and your instructions work perfectly, too, for fixing up the sticky gas pedal problem by applying lithium grease(or prefered lubricant) to the sticking pedal plastic hinge. Never had that nasty sticky/notchy gas pedal problem again after I greased the gas pedal hinge.
Again, thanks.. Now that I know how easy it is to change the brake switch (thanks to your clear instructions), I will not get mugged again by my dealership high labor costs.
There is a difference between gladly paying high dollars for high quality labor, parts, and expertise, and being forced to pay high dollars for highly over charged minimal procedures on sub-quality/defective/under-designed parts.
Thanks again..
AC
2005 ML 500
Black, 18" AMG Wheels, 285/60R18 Yokohama Geolander HTS + Bi-Xenons(+ Drew's e-code mod, though the reflectors rusted off and do not give out much light anymore), Yakima roof bars, Akebono pads all around. Former vehicle 2001 ML 320 with 108K miles, when traded, and a large repair/defect history. After all these years of owning my current 2005 ML 500, it is a major unreliable vehicle with a very large/expensive repair/defect history and has been like this since brand new.
AC_ML is offline   Reply With Quote
Old 02-07-2004, 09:14 PM   #6 (permalink)
This is just too easy....
Changed the offending switch on a neighbors ML - took me all of 7 minutes from start to finish. Yes we were timing it and no I wasn't even trying to be fast !
I wonder what the 'standard' MB service time is for this repair ? :-)
I recommended he visit this site to learn more about the inner workings of his ML.
Old 05-18-2004, 12:21 PM   #7 (permalink)
Benza's Avatar
Date registered: Nov 2002
Vehicle: 2004 HUMMER H2 -- 98' ML 320 (Sold)
Thanks Tim! It was very easy and without a doubt saved me a trip to the MB Service Dept.
FYI, anyone with a 98' ML the part# that worked for my ML was 0015452009. If you need to replace this part make sure to bring your VIN # with you so MB can make sure of the correct part.
Thanks again Tim! That publication was a great help! [:)]
Benza is offline   Reply With Quote
Old 05-18-2004, 01:00 PM   #8 (permalink)
UncAl's Avatar
Date registered: Sep 2002
Vehicle: '08 Acura MDX
<a href="http://www.benzworld.org/forums/forums/thread-view.asp?tid=1172738&posts=4&hl=" target=new>Yup.</a>
_______________
'08 Acura MDX w/ Tech package
Previously - '98 ML320 - 285k miles in 7 years
UncAl is offline   Reply With Quote
Old 05-18-2004, 01:17 PM   #9 (permalink)
jdanish's Avatar
Date registered: Sep 2003
Vehicle: ML500, 2005
Dealer labor for switch replacement .5hr
switch price $11.50
jd
jdanish- 2005 ML500
Independent Repair Shop Owner
ASE Master Technician, FAA Certified Flight Instructor
jdanish is offline   Reply With Quote
Old 05-19-2004, 10:45 AM   #10 (permalink)
Benza's Avatar
ETS BAS light's still coming on
Afer replacing that part, the ETS BAS light's went away but now are coming on again (1 day later). Any idea of what else may be causing this?
TIA
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
