Old 01-24-2004, 06:44 PM   #1 (permalink)
Date registered: Jan 2004
2001 ML430 Navigation
I recently bought a 2001 ML 430 with navigation on ebay. The truck came from Ga and I am in RI. It didn't come with a Navigation CD. I bought a CD on ebay, inserted it, all seemed fine. I punch an address in and it says to keep driving for a while. My GPS Info shows my coordinates but there are 0 satellites picking me up. Any ideas what might be wrong? I'm under the assumption that this was not an aftermarket addition. I look forward to hearing anyone for help.
agiul is offline   Reply With Quote
Old 01-25-2004, 04:06 AM   #2 (permalink)
Vehicle: 2002 ML55K
Send a message via AIM to jdbower Send a message via MSN to jdbower
RE: 2001 ML430 Navigation
Frequently when the GPS coordinates are very different from expected, the system gets confused. Drive it for a few hours and things should get cleared up. The cold-start synchronization is pretty bad, but there are very few occasions when it's needed. Also make sure that you drive under an open sky without too many trees or tall buildings in the way.
Thanks,
Jeff
<hr><small>2002 ML55 (debadged), <A HREF="http://www.benzworld.org/forums/forums/thread-view.asp?tid=46299&posts=20" target="_blank">Metallic Black Rear Star</A>, 2003 DVD Navigation, fire extinguisher, OEM trailer hitch, OEM Smoke Hood Deflector, OEM Smoke Sunroof Deflector, OEM basic carrier, v60, VES, CD Changer, <A HREF="http://www.*************.com/contsp/product.asp?intProdID=D-ML163-LED-Painted&model=W163&category=LED+Brake+Lights+" target="_blank">LED rear wing</A>, <A HREF="http://www.*************.com/mb_results_m.asp?model=W163&class=m-class&category=LED+Replacement+Bulbs" target="_blank">LED brakes and rear turn signals</A>, <A HREF="https://www.designtech-intl.com/merchant.ihtml?pid=47&lastcatid=12&step=4" target="_blank">DesignTech halogen backup bulbs</A>, <A HREF="http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&category%5Fname=CT LG%5F010%5F012%5F011%5F000&product%5Fid=276%2D272" target="_blank">amber ambiant passenger footwell lighting</A>, <A HREF="http://www.valentineone.com/home.asp" target="_blank">Valentine V1</A>, <A HREF="http://www.ssiamerica.com/products/neo35/index.shtml" target="_blank">Neo Car MP3 player</A>, <A HREF="http://www.tirerack.com/accessories/smartire/smartire2.jsp" target="_blank">SmarTire wireless tire pressure monitoring</A>, ML430 winter rims with Dunlop WS M2 tires (255/60R17), <A HREF="http://www.benzworld.org/forums/forums/thread-view.asp?tid=45318&posts=20" target="_blank">crossdrilled/slotted/frozen/nickel plated rotors</A>, <A HREF="http://www.benzworld.org/forums/forums/thread-view.asp?tid=61783&posts=20">Autobahn mirror, rear fresnel lens</A>, <A HREF="http://www.benzworld.org/forums/forums/thread-view.asp?tid=69466&posts=20">SnowBear Utility Trailer</A>, <A HREF="http://www.escortradar.com/gtimer.htm">Escort GTimer GT2</A>, silver/polished <a href="http://www.hrewheels.com">HRE</a> <a href="http://images2.hrewheels.com/wheels/images/enlarge/enlarge-645r.jpg">645R</A> 20x9.5 <A href="http://www.wheelboutique.com">rims</A> with matching 295/40ZR20 <A HREF="http://www.tirerack.com/tires/tires.jsp?tireMake=Dunlop&tireModel=SP+Sport+9000& partnum=94ZR09000">Dunlop SP9000s</A>, <A HREF="http://www.kleemann.dk/tuning/index.htm">Kleemann Supercharger and ECU upgrade (550HP and 502 ft-lbs!)</A>. </small><center><HR>BMW is "Wanted, Mercedes Benz" backwards.<br><a href="http://www.benzworld.org/forums/view-profile.asp?action=view&uid=1044">tcp_ML500</a> says: Jeff's ML55K blows but BenzWorld doesn't!</center>
jdbower is offline   Reply With Quote
Old 01-28-2004, 04:03 PM   #3 (permalink)
Date registered: Jun 2003
Vehicle: 2001 ML320
I had the same problem recently after my MCS locked up and wouldn't come on anymore. The dealer replaced the fuse but I wasn't getting any satellites.
Had to take it back a second time and they replaced the GPS antenna. It's been fine since.
fdillard is offline   Reply With Quote
Old 01-28-2004, 05:02 PM   #4 (permalink)
roadsession's Avatar
Date registered: Nov 2002
Vehicle: 99 ML320 C230 530xi
agiul - 1/24/2004 8:44 PM
Same thing when I bought retrofitted my Nav into my ML. The Nav unit was from NYC. So here's what I had to do:
The MCS satellite signal icon that shows reception comes on only after signals from at least 6 satellites has been fixed and confirmed.
Here's the procedure:
A) Leave the car in an open area where it can acquire
the satellite signals. Leave the MCS ON (key
position 2) and have the car parked for at least
20 to 30 mins.
B) MCS will then slowly acquire the needed satellites and fully recalibrate.
Check satellite signal by going to
OPTIONS
GSP INFORMATION
It will tell you number of satellite signals
acquired.
C) If above doesn't work, then you may have a bad
antenna
BMW E60 530xi
MB W163 ML320
MB W202 C230
roadsession is offline   Reply With Quote
Old 01-28-2004, 07:02 PM   #5 (permalink)
Wolfgang's Avatar
Vehicle: MBs
roadsession - 1/28/2004 4:02 PM
antenna
...and before buying a new one, check that the antenna is tightened down. Remove the little cap, then use a wrench to tighten it so it makes contact with the roof. If it doesn't make contact, no satellites can be acquired.
Wolfgang is offline   Reply With Quote
Old 01-30-2004, 05:33 PM   #6 (permalink)
Ok thanks for the info. I forgot to mention that Tele Aid was tracking me while my Navigation was down. Which should mean the problem lies between the splitter and the MCS. Unfortunately after I sent my truck into the dealership Tele Aid doesn't track me anymore. Thats an issue that I am taking up with the dealership. Also how do I get to the Antennae
Old 01-30-2004, 07:03 PM   #7 (permalink)
Tim
Vehicle: 2001 ML320
The Teleaid GPS and the NAV are completely independant. Since both have quit working it sounds as if it might be the antenna, or booster (shown in the above photo). The splitter is actually downstream from the booster which is mounted under the passenger seat.
<a href="http://www.urbanplanet.org/" target="_blank"
title="Visit UrbanPlanet.org"><img
src="http://www.midtechonline.com/images/banners/up_citytalk_88x15.gif"
width="80" height="15" border="0" alt="Visit UrbanPlanet.org"></a>
Tim is offline   Reply With Quote
Old 07-17-2006, 11:29 AM   #8 (permalink)
Date registered: Jul 2006
Vehicle: ML430
Can you tell me which fuse I had to change
lmo2bety is offline   Reply With Quote
Old 07-17-2006, 01:27 PM   #9 (permalink)
Wolfgang's Avatar
Vehicle: MBs
There should be a label under the lid of your E-Box under the hood. It looks like this.
Old 07-25-2006, 01:38 PM   #10 (permalink)
Vehicle: ML430
Thank you very much for your help. It did work
I pulled the fuse # 21 and put it back which reset the navigation system.
Thanks Elmo
