Old 01-23-2004, 10:29 AM   #11 (permalink)
Vehicle: 2002 ML55K
Send a message via AIM to jdbower Send a message via MSN to jdbower
RE: I think your seats work without the key in place in which case
Hmmm. I'd still be worried about battery drain but you may be able to kill two birds with one stone. How about getting one of those jump-start kits (essentially a portable battery with built-in jumper cables. Plug that into the switched outlet and use it to power the DVD player. You may be able to store one discretely under a seat for a cleaner install. This way you'd have some amount of battery backup for the DVD player without draining the battery and it would be useful in case you (or anyone else) really needs a jump.
Thanks,
Jeff
<hr><small>2002 ML55 (debadged), <A HREF="http://www.benzworld.org/forums/forums/thread-view.asp?tid=46299&posts=20" target="_blank">Metallic Black Rear Star</A>, 2003 DVD Navigation, fire extinguisher, OEM trailer hitch, OEM Smoke Hood Deflector, OEM Smoke Sunroof Deflector, OEM basic carrier, v60, VES, CD Changer, <A HREF="http://www.*************.com/contsp/product.asp?intProdID=D-ML163-LED-Painted&model=W163&category=LED+Brake+Lights+" target="_blank">LED rear wing</A>, <A HREF="http://www.*************.com/mb_results_m.asp?model=W163&class=m-class&category=LED+Replacement+Bulbs" target="_blank">LED brakes and rear turn signals</A>, <A HREF="https://www.designtech-intl.com/merchant.ihtml?pid=47&lastcatid=12&step=4" target="_blank">DesignTech halogen backup bulbs</A>, <A HREF="http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&category%5Fname=CT LG%5F010%5F012%5F011%5F000&product%5Fid=276%2D272" target="_blank">amber ambiant passenger footwell lighting</A>, <A HREF="http://www.valentineone.com/home.asp" target="_blank">Valentine V1</A>, <A HREF="http://www.ssiamerica.com/products/neo35/index.shtml" target="_blank">Neo Car MP3 player</A>, <A HREF="http://www.tirerack.com/accessories/smartire/smartire2.jsp" target="_blank">SmarTire wireless tire pressure monitoring</A>, ML430 winter rims with Dunlop WS M2 tires (255/60R17), <A HREF="http://www.benzworld.org/forums/forums/thread-view.asp?tid=45318&posts=20" target="_blank">crossdrilled/slotted/frozen/nickel plated rotors</A>, <A HREF="http://www.benzworld.org/forums/forums/thread-view.asp?tid=61783&posts=20">Autobahn mirror, rear fresnel lens</A>, <A HREF="http://www.benzworld.org/forums/forums/thread-view.asp?tid=69466&posts=20">SnowBear Utility Trailer</A>, <A HREF="http://www.escortradar.com/gtimer.htm">Escort GTimer GT2</A>, silver/polished <a href="http://www.hrewheels.com">HRE</a> <a href="http://images2.hrewheels.com/wheels/images/enlarge/enlarge-645r.jpg">645R</A> 20x9.5 <A href="http://www.wheelboutique.com">rims</A> with matching 295/40ZR20 <A HREF="http://www.tirerack.com/tires/tires.jsp?tireMake=Dunlop&tireModel=SP+Sport+9000& partnum=94ZR09000">Dunlop SP9000s</A>, <A HREF="http://www.kleemann.dk/tuning/index.htm">Kleemann Supercharger and ECU upgrade (550HP and 502 ft-lbs!)</A>. </small><center><HR>BMW is "Wanted, Mercedes Benz" backwards.<br><a href="http://www.benzworld.org/forums/view-profile.asp?action=view&uid=1044">tcp_ML500</a> says: Jeff's ML55K blows but BenzWorld doesn't!</center>
jdbower is offline   Reply With Quote
Old 01-23-2004, 10:09 PM   #12 (permalink)
Date registered: Sep 2003
Vehicle: ML 320
RE: Need a 12v, always on wire to tap
Thanks to all. I decided to use the power seat source. I tapped into the ground (brown) and hot (orange) as it comes out of the carpet, right before it plugs into the electric seat harness. Everything works great. It made it much easier to run the wires through the seat and then out of the seat post.
Thanks again for the suggestions.
RickT is offline   Reply With Quote
