Old 01-09-2004, 07:11 PM   #1 (permalink)
N1ML's Avatar
Date registered: Jan 2004
Vehicle: 2000 ML320
18" AMG Rims with P285/60R18 Tire Pressure?
My 2000 ML acame with 18" AMG rims. The tires were P285/50R18. There is nowhere in the manual or on a decal that tells me the correct tire inflation pressure. Now I have replacement tires, P285/60R18. Does anyone know what the inflation pressure should be?
N1ML is offline   Reply With Quote
Old 01-09-2004, 07:23 PM   #2 (permalink)
Where's my auto-leveling?
AndyFracica's Avatar
Date registered: Sep 2003
Vehicle: '06 ML350 '03 E320
RE: 18" AMG Rims with P285/60R18 Tire Pressure?
N1ML - 1/9/2004 8:11 PM
I posted a question in the Tire forum and Luke said to run 32 front and rear on the 50s, I would think the 60s would be the same, but you could ask Luke.
Andy
2006 ML350
723 - Pewter, 104 - Macadamia Interior, H04 - Brown Birds Eye Maple Wood, 167 Standard Non-Sport Pkg, 317 Comfort Pkg, 318 - Trim Package, 319 - Lighting Package, 320 - Entertainment Pkg, 324 - Sunroof Pkg, 580 - Std. Climate Control, 873 - Heated Front Seats, 890 - Power Liftgate, Navigation System, iPod interface kit
Modifications:
Added: Chrome Door handle cups, MB Twin Spoke 5-Spoke 18" wheels and tires
AndyFracica is offline   Reply With Quote
Old 01-09-2004, 11:24 PM   #3 (permalink)
AC_ML's Avatar
Vehicle: Black 2005 ML 500
Originally, I bought my new ML with brand new 18" AMG wheels and 285/60R18 B/Duller tires, from
Originally, I bought my new ML with brand new 18" AMG wheels and 285/60R18 B/Duller tires, from the dealer. Later I changed the tires to Michellin's Pilot LTX 285/60R18.
On the gas filler door, you should have a sticker with the recommended tire pressure. Mine says 29 PSI front and back for normal ride.
Even though they recommend 29 psi, each tire provides different feedback to the shocks valving/disks so to achieve the best shock tuning you will have to experiment at various psi's. The more psi, the tighter/stiffer the shock will get and if you put too much air, you will have a tighter ride at highway speeds. If you put too a low psi, then you will have a nice ride, but your ML may wobble a lot. If it wobbles to much, you should increase the air pressure of your tires to make them stiffer and control the wobbling. If you obtain a nice controlled ride at lower speeds, but your highway ride is too stiff, it may help to adjust the torsion bar (lowering a bit your ML) to obtain a smoother ride at highway speeds. If you can't obtain a smooth ride and your ML wobbles too much on rough roads, then you may need to change shocks. Get 2002+ OEM new shocks (if you prefer OEM) since they are supposed to have been tuned better for the ML's..
Currently, I have Bilsteans, and after testing various setups, I found that 38 psi on the front tires and 43 psi on the back tires provides me the best ride at low and high speeds and on rough or smooth terrains.
You need to be careful when inflating your tires since tires have a wide range of maximum pressures. My Michellin Pilot LTX (reinforced) have a maximum of 50 psi, but my B/Dueller the maximum PSI was around 40 psi. You never want to exceed the maximum recommended pressure.
You need to take into account, too, that you will have a 1 psi increase/decrease for each 10 degrees of temperature increase/decrease. In addition, if you drive for a long time, friction will further increase your tire PSI.
AC
2005 ML 500
Black, 18" AMG Wheels, 285/60R18 Falken Ziex ST/Z + Bi-Xenons(+ Drew's e-code mod), Yakima roof bars. Former vehicle 2001 ML 320 with 108K miles, when traded, and a large repair/defect history. After 3 years of owning my current 2005 ML 500, it has become another unreiliable vehicle with a very large/expensive repair/defect history..
AC_ML is offline   Reply With Quote
Old 01-10-2004, 07:35 AM   #4 (permalink)
Vehicle: 2002 ML55K
Send a message via AIM to jdbower Send a message via MSN to jdbower
RE: Originally, I bought my new ML with brand new 18" AMG wheels and 285/60R18 B/Duller tires, from
You can also look into this if you want real-time feedback as to tire temp and pressure:
http://www.smartire.com/fl/products/cars.html
Thanks,
Jeff
<hr><small>2002 ML55 (debadged), <A HREF="http://www.benzworld.org/forums/forums/thread-view.asp?tid=46299&posts=20" target="_blank">Metallic Black Rear Star</A>, 2003 DVD Navigation, fire extinguisher, OEM trailer hitch, OEM Smoke Hood Deflector, OEM Smoke Sunroof Deflector, OEM basic carrier, v60, VES, CD Changer, <A HREF="http://www.*************.com/contsp/product.asp?intProdID=D-ML163-LED-Painted&model=W163&category=LED+Brake+Lights+" target="_blank">LED rear wing</A>, <A HREF="http://www.*************.com/mb_results_m.asp?model=W163&class=m-class&category=LED+Replacement+Bulbs" target="_blank">LED brakes and rear turn signals</A>, <A HREF="https://www.designtech-intl.com/merchant.ihtml?pid=47&lastcatid=12&step=4" target="_blank">DesignTech halogen backup bulbs</A>, <A HREF="http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&category%5Fname=CT LG%5F010%5F012%5F011%5F000&product%5Fid=276%2D272" target="_blank">amber ambiant passenger footwell lighting</A>, <A HREF="http://www.valentineone.com/home.asp" target="_blank">Valentine V1</A>, <A HREF="http://www.ssiamerica.com/products/neo35/index.shtml" target="_blank">Neo Car MP3 player</A>, <A HREF="http://www.tirerack.com/accessories/smartire/smartire2.jsp" target="_blank">SmarTire wireless tire pressure monitoring</A>, ML430 winter rims with Dunlop WS M2 tires (255/60R17), <A HREF="http://www.benzworld.org/forums/forums/thread-view.asp?tid=45318&posts=20" target="_blank">crossdrilled/slotted/frozen/nickel plated rotors</A>, <A HREF="http://www.benzworld.org/forums/forums/thread-view.asp?tid=61783&posts=20">Autobahn mirror, rear fresnel lens</A>, <A HREF="http://www.benzworld.org/forums/forums/thread-view.asp?tid=69466&posts=20">SnowBear Utility Trailer</A>, <A HREF="http://www.escortradar.com/gtimer.htm">Escort GTimer GT2</A>, silver/polished <a href="http://www.hrewheels.com">HRE</a> <a href="http://images2.hrewheels.com/wheels/images/enlarge/enlarge-645r.jpg">645R</A> 20x9.5 <A href="http://www.wheelboutique.com">rims</A> with matching 295/40ZR20 <A HREF="http://www.tirerack.com/tires/tires.jsp?tireMake=Dunlop&tireModel=SP+Sport+9000& partnum=94ZR09000">Dunlop SP9000s</A>, <A HREF="http://www.kleemann.dk/tuning/index.htm">Kleemann Supercharger and ECU upgrade (550HP and 502 ft-lbs!)</A>. </small><center><HR>BMW is "Wanted, Mercedes Benz" backwards.<br><a href="http://www.benzworld.org/forums/view-profile.asp?action=view&uid=1044">tcp_ML500</a> says: Jeff's ML55K blows but BenzWorld doesn't!</center>
jdbower is offline   Reply With Quote
Old 01-10-2004, 09:10 AM   #5 (permalink)
N1ML's Avatar
Vehicle: 2000 ML320
My 2000 ML320 was also purchased in Houston. It was billed as the "Jurassic Park" edition. My wife is the one who really uses it. It has these big tires on it, bull bars, TV monitors in the headrests and other upgraded stuff. I cannot find any reference to the AMG wheels and tires in the manuals. Is this similar to yours? I am trying to find out the story behind this specific model. The tires are at 37 psi and seem to be OK.
Old 01-10-2004, 12:24 PM   #6 (permalink)
N1ML - 1/10/2004 10:10 AM
I would love to see some pictures of your ML. Can you post some?
Old 01-10-2004, 12:52 PM   #7 (permalink)
N1ML's Avatar
Vehicle: 2000 ML320
As soon as it warms up to +5 degrees F I will take a few pics and post them. I think my camera would freeze out there today. Boston weather is not too nice this time of year. [:p]
Old 01-10-2004, 01:11 PM   #8 (permalink)
N1ML - 1/10/2004 1:52 PM
I know what you mean. My sister-in-law and brother-in-law live in Sandwich.
I hear its going to be a cold football game tonight for the Patriots
Old 01-10-2004, 11:08 PM   #9 (permalink)
AC_ML's Avatar
Yes, the dealer had the Jurassic Park package and that is what I partially got..
Yes, the dealer had the Jurassic Park package, MB Houston North was where I bought my ML, and that is what I partially got. I did not want the big front bars, so I chose the smaller front bar. I don't have either the large sun roof.
I guess you will need to look at the ML 55 AMG for information on the AMG wheels and tires since they are standard on them. The dealer is supposed to install the proper tire specific pressure stickers on the gas door. Normally, that will be the correct pressure for the best performance and tuned ride, but if you changed tires types/brands, then depending on the tire construction, properties, and feedback the best ride may or may not be at the recommended tire pressure. I know my B/Duellers 285/60R18 had a stiff vertical tire wall compared to the Michellin Pilot's, which made them more prone to wobble and to be harsher. The Michelly Pilot in my opinion were a great improvement over the B/Duellers.
AC
Old 01-11-2004, 12:45 PM   #10 (permalink)
Bora20's Avatar
Date registered: Sep 2002
Vehicle: 2000 E320S4M
RE: Yes, the dealer had the Jurassic Park package and that is what I partially got..
AC_ML - 1/10/2004 10:08 PM
Proper size tires for the ML55 are 285/50R18, [b]not[/b[ 285/60R18 so looking at the ML55 pressure will not give you the correct pressure, however, the will be close.
Dan - 2000 E320 Wagon 4Matic
Gone - *2002 ML320 Elegance**2001 C240 Sport**1999 E430 Elegance*
Bora20 is offline   Reply With Quote
