Ok, now i'm getting ready to order all my stuff for the nav install. I'm doing this myself, and i think i can do it. However, I was at *, and under the adapters section, they have several cables, splitters and CAN adapters. My 2000 ML320 doesnt have the nav drive (DUH) and i need to know if all these wiring harnesses, cables and splitters are already in place? Or do i need to order them??
i'm pretty sure that u don't have to version code the MCS for the navigation voice. mine didn't need any version coding. play with the settings first and see what u get.
Both Magellan and Garmin have some nice automotive nav systems that can be ported to any car. Some of them with touch screen. Check out the links below.
I believe that on a 2000 ML, you don't need a splitter nor the extra cable. The splitter is just for Teleassist equipped MLs as they share the same antenna. Teleassist did not start until 2001. The NAV cable should already be in place behind the dashboard. Just make the connection.
Also, you will need to order a satellite antenna. Most 2000's dont have them installed. You will have to install this antenna on the roof of the ML and make the connection to the other end of the NAV cable.
Actually I don't believe that is exactly correct. On 2001 and later MLs, there is a splitter AND a signal booster. The splitter is connected after the signal booster to direct one cable to the MCS and the other to the Teleassist. Obviously this isn't needed on non-Teleassist ML's such as the 2000.
Now in past discussions of NAV installs in MY 2000 ML's the amplifier was already installed and one only needs to connect the NAV/MCS on one side and the Sat Antenna on the other side.
Tim and Benza, you are both correct, just talking about different parts. There is one box, called splitter/amplifier which one needs in MY2000, and another called "antenna switch" which is actually an HF relay, and looks like a splitter to connect the antenna coax to the TeleAid system under the passenger seat. Here's an approximate schematic for the different ML years on this page:
http://www.whnet.com/4x4/phones.html
Much better diagrams are also available online (install WHIP first, to pan and zoom):
http://www.startekinfo.com
