Head gasket or not ???? - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 03-18-2017, 10:16 AM Thread Starter
Snipersking's Avatar
Date registered: Sep 2011
Vehicle: W140 1998
Quoted: 20 Post(s)
Friends recently I replaced cylinder head and new gasket but I still have oil coming into water reservoir I mean this time pure oil not the milkshake mix, not too much but it gives me headache, by the way, the car does not overheat at all nor hesitate. is there any possible issue other than gasket (where does the oil come from)?
Snipersking is online now
post #2 of 14 (permalink) Old 03-18-2017, 10:38 AM
Date registered: Jan 2013
Vehicle: 1982 MB 380SE 1999 S500
Quoted: 65 Post(s)
First more info.
V8 or 6
How many miles since new gasket?
What is a little? Just sheen or teaspoon?
Have you done a leak down test?
Any sign of bad gasket by bubbles/pressure in overflow reservoir tank?
Why was head changed?
Snipersking likes this.
Drbobme1 is offline
post #3 of 14 (permalink) Old 03-18-2017, 10:40 AM
Steve_B's Avatar
Date registered: Jan 2016
Vehicle: 1993 V12 coupe
Quoted: 145 Post(s)
AFAIK, the head gasket is the only known culprit for mixing coolant and oil on a standard ICE.
If you have oil in the coolant, and you sure that the head gasket job was done correctly, the, I might suspect that what you're seeing it is not engine oil but ATF. What is the color of the oily film in the reservoir?
The transmission cooler is an integral part of the radiator, and if there is a leak, you'll be mixing ATF and coolant. NOT good. Stop driving and investigate right away.
Good luck,
Steve
MAVA and Snipersking like this.
Steve_B is offline
post #4 of 14 (permalink) Old 03-18-2017, 10:54 AM Thread Starter
Vehicle: W140 1998
Quoted: 20 Post(s)
Originally Posted by Drbobme1 View Post
First more info.
V8 or 6
its S320 , how much? its more than teaspoon, about the leak down test, unfortunately our mechanics don't do it, no sign of bad gasket no bubbles or even a pressure in the overflow reservoir tank, the head changed because I had a small crack in on of the valves and the second piston was overflowed with water.
oh the new gasket has just 2000 miles on it.
post #5 of 14 (permalink) Old 03-18-2017, 11:27 AM Thread Starter
Vehicle: W140 1998
Quoted: 20 Post(s)
Good luck,
Steve
I just measured the ATF level and I used a piece of wire 27 inch long from top to the first mark of oil. The oil in the reservoir tank is brown as i said before not even the milkshake color. Could it be I had the cooler?
post #6 of 14 (permalink) Old 03-18-2017, 04:48 PM
Quoted: 65 Post(s)
Have you removed the oil in the reservoir and have it come back? If so, how fast does it return?
Drbobme1 is offline
post #7 of 14 (permalink) Old 03-18-2017, 08:23 PM
Joe-Trojan's Avatar
Date registered: Jan 2014
Vehicle: 98 S420 96 S600 Fixing 96 S500 92 600SEL Past 96 S280 x2
Quoted: 400 Post(s)
Joe-Trojan is offline
post #8 of 14 (permalink) Old 03-18-2017, 10:35 PM Thread Starter
Vehicle: W140 1998
Quoted: 20 Post(s)
Yes I did two times and it comes back within a week.
post #9 of 14 (permalink) Old 03-18-2017, 10:38 PM Thread Starter
Vehicle: W140 1998
Quoted: 20 Post(s)
Originally Posted by Joe-Trojan View Post
If it's a RHD car it's the oil cooler under the manifold at rear next to the oil filter.
No its not a RHD car.
Joe-Trojan likes this.
post #10 of 14 (permalink) Old 03-19-2017, 01:43 PM Thread Starter
Vehicle: W140 1998
Quoted: 20 Post(s)
First more info.
V8 or 6
could it be possible that oil escape through this timing chain cover as shown in the picture attached below due to bad o ring
