I finally took possession of a 1995 S320 and now working through a few niggling issues. The major item is the lack of wiper, turn signal, or hazard. Research suggests that the N10 relay is the primary culprit.
I found a replacement relay, brand new but costs USD500.00! I noticed however that my part number has a [4] after the part number, but the replacement has not. What is the significance of this?
My unit
Replacement
Given the cost, I want to check a few things first.
I had a indie check the relay last weekend and we noticed that one of the pins in the bank of ~17 was burnt. Likewise, fuse #15 kept burning! Could the relay be the cause of this? Or might there be an electrical issue that needs investigation?
I will attempt to clean the relay tomorrow, before I consider purchasing that expensive part!
My unit
Replacement
