SE 300 , BEST REGARDS TO ALL - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W140 S-Class
Old 12-05-2012, 12:33 PM   #1 (permalink)
Date registered: Dec 2012
Post SE 300 ,ENGINE WASHED BY WATER !!!!!!!!
hello every one, i am having a little problem with my MERCEDES BENZ SE 300 , YEAR 93 . I bought it used in good condition.
MERCEDES BENZ
i took it to the car wash and wash it all with water , i opened the hood and wash the engine also with water. the car starts i drove to home and sudenlly it stoped. DID THIS HAPPENED TO ANY ONE OF YOU!! ,
PLEASE reply to my issue, i am totaly confused !!
My bests
M
CIGAR_LOUNGE is offline   Reply With Quote
Old 12-05-2012, 12:51 PM   #2 (permalink)
z168's Avatar
Date registered: Oct 2005
welcome and pls update your location
there is a good chance the water got into your ignition coil and is messing it up.
Deutsche Tourenwagen Meisterschaft
z168 is offline   Reply With Quote
Old 12-05-2012, 01:15 PM   #3 (permalink)
engine is fine, i hope
Well ,
the car now is parked and i don't know what to do !! do i leave it to dry then it will start again, if so how long to let it dry,
did this happened to you !! is it a serious problem !!
Old 12-05-2012, 01:25 PM   #4 (permalink)
Mercedes>Bmw's Avatar
Date registered: Apr 2012
Vehicle: 2010 Acura TSX 71K, 2011 Mazda3 55K, 2000 Chrysler Grand Voyager SE 107K
Your not supposed to wash your engine like that, next time don't.
The W140- Measuring yourself by a benchmark is one thing, Setting it is another
Mercedes>Bmw is offline   Reply With Quote
Old 12-05-2012, 03:07 PM   #5 (permalink)
Date registered: Jun 2010
Vehicle: 1995 S500 coupe, 1995 C280, 1983 380SL, 1990 Mazda Miata
Check the inside of the distributor cap for wetness. Even though it started after you washed it, sometimes the heat combined with water will cause moisture to get under the cap and will cause the engine to die.
95Scoupe is offline   Reply With Quote
Old 12-08-2012, 10:58 AM   #6 (permalink)
My bests
problem solved thanx to all,
it was so easy to deal with.
M
Old 12-08-2012, 11:03 AM   #7 (permalink)
Rch.Org's Avatar
Date registered: Jul 2009
Vehicle: C140 M119
How did you solve it?
Rch.Org is offline   Reply With Quote
Old 12-09-2012, 10:42 AM   #8 (permalink)
It was so eassy.
hi again ,
i took the car to MERCEDES BENZ Prof, he changed the spark plugs, then some coils cleanings ,
it starts again.
clean with GAZ is ok
MERCI
M
Old 02-11-2013, 10:24 AM   #9 (permalink)
M
Bookmarks
