combination relay wiring help - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W140 S-Class
Old 11-19-2012, 12:26 PM   #1 (permalink)
Date registered: Nov 2012
Vehicle: 95 mercedes s320
im new to this. have a 95 s320. noticed that the s500 is slightly different. read all the post i can find about the combination relay. my problem is this car came from a shop that messed up the plug and pulled the wires out of it. i have michell online and still cant find a wireing diagram for the combination relay. and i noticed that the arent really that reliable anyway. does anyone have one? or be willing to take some pictures of theres so i can put mine back together? any help will be apreciated.. thanks!
d_mann77 is offline   Reply With Quote
Old 11-20-2012, 03:58 AM   #2 (permalink)
Date registered: Jan 2003
Vehicle: 87 300TD, 95 S280 (Diesel Conversion 2.9L Turbo OM602)
There are 4 connectors coming out of the combination switch... each have their own style plug so its basically fool-proof. Just find the corresponding plug.
Locry is offline   Reply With Quote
Old 11-20-2012, 05:24 AM   #3 (permalink)
bobs's Avatar
Date registered: Dec 2007
Vehicle: '97 S320 (LWB), '01 E320
Yep, it should be pretty apparent where the plugs go, with the exception on a single wire plug that comes from the rain sensor. There are two places where that one can fit. Don't ask me how I found that out.
Now, if you meant that the previous shop pulled the wires out of the connector, that's another story entirely! If you have access to a schematic diagram, the relay in question is designated N10. Hopefully that will help.
"It's not about how fast you can go, but how well you can go fast."
'97 S320 (LWB), Ruby Red Metallic/Tan, 75k miles
'01 E320, Black/Charcoal, 90k miles
Gone but not forgotten. . .
'97 S420V, Smoke Silver Metallic/Tan, (RIP 22 Oct 2012, 178627 miles) He gave his life to save mine.
bobs is offline   Reply With Quote
Old 11-20-2012, 05:29 AM   #4 (permalink)
Paul Axelsson's Avatar
Date registered: Oct 2011
Vehicle: Mercedes 320 SE 1991
I've had the same problem, had to wiggle each pin into the connector, very frustrating but worked in the end. Don't have a wiring diagram though
http://www.benzworld.org/forums/w140...pensive-s.html
Paul Axelsson is offline   Reply With Quote
Old 11-20-2012, 11:02 AM   #5 (permalink)
thanks for the link. unfortunately i wasent that lucky. they gave the car back to the guy and said they couldent fix it. this is what i found under the relay
combination relay wiring help-pict0002.jpg   combination relay wiring help-pict0005.jpg
Old 11-20-2012, 11:52 AM   #6 (permalink)
bobs's Avatar
Ouch! Yes, it looks like you're going to need someone with the same car to show you their connectors. I poked around alldatadiy, and while they have a bunch of schematic diagrams that show wire colors and pin numbers, they don't seem to have one that shows the wiring of the N10 in its entirety. You might be able to piece it together if you search around there enough.
I also found this thread which my prove useful:
http://www.benzworld.org/forums/w140...y-problem.html
Old 11-20-2012, 12:06 PM   #7 (permalink)
Rupununipete's Avatar
Date registered: Sep 2011
Vehicle: 1952 W187(sold), 1979 230C Euro Coupe, 1987 300E (the beater), 1992 600SEL W140 (latest project),
I have attached the schematic from AllData for my '92 600SEL
I hope it is of some help to you. It would be best if you could get an image of the colour wires going into the connector.
Good luck!
Rupununipete is offline   Reply With Quote
Old 11-20-2012, 12:57 PM   #8 (permalink)
Date registered: Feb 2008
Vehicle: 1997 SL600 Silver with grey/dark metal interior, 140K miles
Usually the wires on the plug's mate will match colorwise wire for wire.
mahunt is offline   Reply With Quote
Old 11-20-2012, 01:46 PM   #9 (permalink)
i have been going through mitchell printing off component diagrams that this relay runs but still cant find all of them. even contacted mitchell and they just dont have it. and as i said. i have noticed in the passed that the wire colors in the diagrams are not always correct. i just dont wanna get something wrong and cause more problems. pictures of the same car plug would be the best. thanks for the help everyone. some of this has been usefull
Old 11-20-2012, 02:07 PM   #10 (permalink)
Here is the pin assignment for a 1995 and later models for all the combination relay connectors (the one you need is on the last page). Hope it helps, good luck!
File Type: pdf W140 Combination Relay Pin assignment from 09_95.pdf (36.0 KB, 60 views)
Bookmarks
