Hey Jayare,
Again, I appreciate your help on this, and I understand that I'm not a 'genius' at DIY. That being said, so far, I've changed the following by myself:
- Spark plugs
- Fuel Filter
- Fuel Pump
- All 8 fuel injectors ( which was hard
but it worked )
- Radiator
So I'm not totally 'stupid' lol , I can do some repairs by myself..
Anyways, back to the original topic:
Here is a picture of the distributor cap:
Here is a picture of the rotor:
I know how to change distributor cap/rotors, but not ignition coils. The reason for that is because I dont really know where they are (again, I could really use some picture-help).
This is a picture I found on the internet (its a picture of s500 engine, which is not my car, but looks almost identical):
Are you talking about removing the cover that is directly behind the DRIVER SIDE headlight ? Not the one to change your headlight bulbs, but the cover directly behind that ?
And yes, I don't think rotors,caps,ignition wires,spark plug wire have ever been changed on this car.. so It's definitely time. Any thoughts of how to change ignition wires/spark wires ? Is it as simple as it looks? I'm guessing I unplug each spark plug wire from both sides and put a new plug wire (remove , plug and play) ? same goes for ignition wires?
Thanks again for your help Jayare, I really appreciate it (the only way i'm ever gonna better my knowledge with W140's is by talking to experts, so thanks again
Adam
