ignition coils left and right - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 05-08-2012, 07:00 AM Thread Starter
donkshophorse's Avatar
Date registered: May 2010
Vehicle: 1993 S600 coupe (RHD)
i am planning to swap my 2 original ignition coils and have two replacement working coils but they are both from the one side of the vehicle and i noticed when i looked inside my car the layout/configuration is different on each side of the vehicle. do you know does it matter if i put one on the car that has a slightly different layout/configuration? the two i have are the same layout as for the passenger side (right hand drive). so can i use one for the driver side, providing i get the cable layout to fit, or will it cause some kind of electrical issue on the car? i noticed that the two small wire connections have different diameter threads and so would be careful to ensure that the cables are wired correctly of course.
donkshophorse is offline
Do I need new Ignition Coils??? quakercity W140 S-Class 8 04-22-2011 02:50 PM
ignition coils kevin2010 R129 SL-Class 16 01-06-2011 08:51 PM
Are the right and left ignition coils different MGYVER R129 SL-Class 12 04-05-2010 10:00 PM
Help---ignition coils migg48 W140 S-Class 2 01-14-2008 02:26 PM
Ignition Coils Phil G-Class 2 11-28-2005 06:24 PM
