Outside mirror removal? - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 04-04-2012, 02:40 PM Thread Starter
jcvollmuth's Avatar
Date registered: Dec 2010
Vehicle: 1995 s500, 2004 s500, 1991 190e
Can somebody inform me on how to take my mirrors off, the only DIY thread I could find was good but it looks completely different, I don't have anything to unscrew. my mirrors don't power fold but the motors work, the driver side mirror moves about 1/2 inch the passenger side mirror doesn't move at all but I can hear the motors working.
ID:	436088   Click image for larger version
ID:	436089   Click image for larger version
jcvollmuth is offline
post #2 of 3 (permalink) Old 04-04-2012, 03:35 PM
Date registered: Jan 2010
Vehicle: 1995 S320 SWB, 1997 S420 LWB
For the pre-96 you have to remove it from the inside. Read part B of this pdf document titled "Complete exterior mirror". Oh and by the way, I had this problem in my 95 all you need is WD-40 and thoroughly spray the metal hinges and they will work again. I discovered the mirror wiring problem was only in the post 96 mirror. My 97 had degraded wire and I had to put heat shrink tubing over them. No more fuse blowing. The pre-96 mirror wiring is inside the cover and very solid as you will see.
drcane is offline
post #3 of 3 (permalink) Old 04-04-2012, 04:09 PM Thread Starter
jcvollmuth's Avatar
Wow, I just tried some wd 40 and the drivers side works good now, I never would have thought it would have been such an easy solution, passenger side still doesn't budge, I'm probably going to have to remove it so thank you very much for your post
    Side mirror removal Gregs300CD W123 E,CE,D,CD,TD,TE Class 8 03-17-2015 05:31 AM
    mirror removal ? carolina new be W163 M-Class 2 08-18-2010 05:22 AM
    Mirror removal mvbiondi W126 S,SE,SEC,SEL,SD,SDL Class 2 06-22-2009 08:42 AM
    Mirror Removal 79Mercy W123 E,CE,D,CD,TD,TE Class 15 05-11-2007 06:46 PM
    Mirror Glass removal Louie_D W126 S,SE,SEC,SEL,SD,SDL Class 1 09-12-2006 12:00 AM
