How to replace key battery for 96 S320? - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 02-01-2012, 07:44 PM Thread Starter
OCMD's Avatar
Date registered: Jan 2008
Vehicle: none
It just seems like it takes forever to lock my car with the key being aimed at the rear view mirror. I'm thinking there is a battery in the key. I do not want to try and pry anything open without knowing what I am doing. It is a key to a 96 S320. The key "box" (for lack of a better descriptor) is black, about 2 inches long and one inch wide rectangle, with a tiny button on upper left corner which you push to get the key to pop out of the side of the rectangle. Thanks for any ideas/help.
96 S320, 135K and counting.....
10 Honda Odyssey....who cares
01 Chevy Silverado....41K and moving slowly....
01 Yamaha LS2000 Water Rocket....on 2d set of engines.."sit down, hold on, and shut up!
OCMD is offline
post #2 of 7 (permalink) Old 02-01-2012, 11:20 PM
rikana's Avatar
Date registered: Feb 2011
Vehicle: W140 S320 1998
Quoted: 9 Post(s)
Hi OCMD,
There is definetly a battery in there. When mine was dead I took it to one of those small gadet repair shops who changed the battery for about $5. Then I was able to reprogram he remote and alarm and now my system works great. How many buttons are on your remote? The older remote has only one button and there is a 3 button version that includes a trunk opener.
regards
rikana is offline
post #3 of 7 (permalink) Old 02-02-2012, 01:03 AM
W140 Moderator
Merc-S600's Avatar
Date registered: Aug 2007
Vehicle: Merc 93 W140 S600 / Merc-05-413CDI-Sprinter Turbo / Merc-09 B180-CDI / Holden Rodeo RA 3.5L V6 <
Quoted: 396 Post(s)
If your's is the same Key like mine then look here ,made specially for you .
Ciao
Change of Batteries for Mercedes W140 Flipkey (93 Model) - YouTube
>->->- My-S600 ->->->-
--"VENI-VIDI-VICI"--
"I came-I saw-I conquered".
Driving a W140 & everything else feels like is standing still .
Everything you like to know about the W140's
>>>> " http://www.mb-w140.de/ " <<<< .
==============ALL AUSTRALIAN W140 OWNERS ,CLICK ME:==============
Merc-S600 is offline
post #4 of 7 (permalink) Old 02-02-2012, 05:12 AM Thread Starter
OCMD's Avatar
Vehicle: none
Rikana: I have one button, very similar in fact almost identical to the key in the You tube video provided by Merc S500. Thank you both. is it easy to re- program the key? Thanks!
OCMD is offline
post #5 of 7 (permalink) Old 02-02-2012, 05:23 PM
W140 Moderator
Merc-S600's Avatar
Quoted: 396 Post(s)
Originally Posted by OCMD View Post
is it easy to re- program the key ?
This PDF file posted from 1 off our members "Peter Guenther" should solve that mistery for you .
Ciao
post #6 of 7 (permalink) Old 02-02-2012, 08:58 PM
rikana's Avatar
Quoted: 9 Post(s)
Hi,
Its as easy as Merc s500 has posted. I discovered on mine that if you press on the lock button and aim at a door handle, it raises the windows. I am not sure if this is on all of them or the later models.... Pretty cool!!!
rikana is offline
post #7 of 7 (permalink) Old 02-03-2012, 12:38 AM
W140 Moderator
Merc-S600's Avatar
Quoted: 396 Post(s)
LoL,when you close the car with the key & you happen to have windows and sunroof open ,hold the flipkey button press't until all windows and also the Sunroof closes automatically , now the good part is that when you come back to the car say about half an hour later ,press the button on the remote ,hold it until the windows /sunroof go back to the same position they were in when you closed the car before but make sure your windows & Sunroof are synchronized in properly otherwise it wont work,there is also another hidden function on that remote but i havn't tested it to be 100 % sure that it is an actual function ,more on that when i'm sure about it ,it involves twisting it left /or right ,(?) .
Rikana;you dont need to aim it ,get a sniperscope for that (lol),if your batteries are ok and all is functioning ,just aim it at the car ,anywere pratically
    Battery solution for s320 Pradeep Sanghvi W220 S-Class 7 12-05-2012 03:23 PM
    S320 wire harness replace COMPATIBILITY 94 / 96 MafiaDON W140 S-Class 0 08-03-2011 03:34 PM
    Need assistance to replace right rear window on 1996 S320 emcee007 W140 S-Class 1 10-18-2010 12:08 AM
    Battery Replacement 97 s320 defcon99 W140 S-Class 3 12-11-2008 08:31 PM
    how to replace the fuel filter on a S320 S3201994 W140 S-Class 1 01-03-2007 12:37 PM
