Close assist system s280 missing part - Page 3 - Mercedes-Benz Forum
post #21 of 41 (permalink) Old 12-30-2011, 05:15 AM
television's Avatar
Date registered: Sep 2005
Vehicle: 216 with everything. 2002 SL500 with everything. 2009 SL500 with everything.
Quoted: 148 Post(s)
The yellow pipes are all the locking including the trunk handle, all of my other 4 are occupied.
If the pump was second hand then it will have been programmed.
Look inside the rear of your trunk lid and there is a hole with a lever in it, it nay have been moved fully left for operation when the PSE pump has failed
Malcolm
"I thought my vasectomy would keep my wife from getting pregnant but apparently it just changes the color of the baby."
television is offline
post #22 of 41 (permalink) Old 12-30-2011, 07:30 AM
syljua's Avatar
Date registered: Sep 2004
Vehicle: 1998, C140, CL500
Quoted: 41 Post(s)
Originally Posted by DJ YOHAN View Post
Why do you have a missing hose from the left top on the black connectors?
Mine look exactly the same connection wise but I have one more hose on top which you have not connected, and I might have to switch to top 2 hoses on the black connectors. At least I will try. Thanx man , you were big help, lets see what can I make out of it.
Attila
Sorry, had to search im my own old post there;
http://www.benzworld.org/forums/w140...se-please.html
So the temp disconnected one is for Lumbar (M for Multicontour). I was figuring out
why that did not work at the time.
Which brings me to the programming of the unit. I think thats not a special thing for the 1998 one. Dependent on equipment, the PSE has to be told what to expect to drive.
Here is a screenshot from the PSE Version Coding dialog in HHTWIN;
As you can see, its only the existence of automatic A/C (yes, the w140 could be
had without it), Lumbar, and Rear hear restraint release together with trunk lid remote
release. (As for the grouping of the last two, I think they share the lines somewhat).
br,
syljua
C140 CL500 1998
W123 230E 1984
syljua is offline
post #23 of 41 (permalink) Old 12-30-2011, 09:49 AM Thread Starter
DJ YOHAN's Avatar
Date registered: Dec 2011
Vehicle: Mercedes S280 1998
Ok I understand, so it is for lumbar support. I have that working just fine so as the rear headrest release.
the only thing I still cant figure out is the boot close assist . Need to wait until stops raining cause it's been pouring all day.
But yesterday I had it all taken out from the lid, checked the airlines and seems ok. Not tested them just visual check.
I cant get the retractable thing to release manually with that lever on left. It does not move in any direction.
I will give it a try when it will be dry weather ( yeah.... like that is likely to happen in Scotland a lot..... LOL)
DJ YOHAN is offline
post #24 of 41 (permalink) Old 12-30-2011, 12:07 PM
television's Avatar
Quoted: 148 Post(s)
When I bought my car the PSE pump was out of order and the boot lid has in the manual mode. I took all of my lock out of the lid all to no avail.
What you should have been told is to check the running time of the pump, if it runs for more the a few seconds it will go the same way as the old one.
Does your button on the dash release the lid, if not then the actuator in the bottom lock has failed the same as mine, Once I blocked the pipe while waiting for the vacuum actuator (£12) I blocked off the pipe to stop the pump from over running, then the handle in the boot came to life.
Forget about close assist till the lock is correct
Malcolm
post #25 of 41 (permalink) Old 12-30-2011, 01:12 PM Thread Starter
DJ YOHAN's Avatar
I checked my pump and it runs about 4-5 sec before it stops.
so it looks like the actuator is gone as it does not work by pressing the switch inside the car. I can only open the boot lid by pressing the keyhole button. But it locks and opens as with the rest of lock as I operate the central locking mechanism. So which actuator has to be replaced if any?
DJ YOHAN is offline
post #26 of 41 (permalink) Old 12-30-2011, 01:27 PM
television's Avatar
Quoted: 148 Post(s)
If the remote will not actually open the lid and neither will the inside switch then I feel that actuator in the bottom is not working.
Just pull the plastic rivet studs out of the plastic trim over the opening and lift it off, bend the carpet down and undo the bolts holding the lock and lift it out, the air pipe and actuator clip into the left hand side.
By pushing down the lock catch it should pop up if all good on the remote
Malcolm
post #27 of 41 (permalink) Old 12-30-2011, 01:46 PM
television's Avatar
Quoted: 148 Post(s)
It would not let me edit my last post but you can test it all out by simply pressing down the lock catch with your finger, and the remote or inside switch should release it
Malcolm
post #28 of 41 (permalink) Old 12-31-2011, 06:08 AM Thread Starter
DJ YOHAN's Avatar
Ok here we go. Today I checked again and had to swap 2 hoses on a PSE pump. The 2 bottom hoses ( black and double white ) were swapped over and my retractable tongue and handle at back came to life. On the other hand the rear head restraint stopped working and the inside switch still does not operate the trunk release.
Took all out again and found hidden in body there is a cable hanging loose again and it is connected to the microswitch in the lock as you can see on the picture. I tried to look for a connection to it but there is none. Please if somone knows where to connect that cable please let me know.
Name:	just now 021.jpg
DJ YOHAN is offline
post #29 of 41 (permalink) Old 12-31-2011, 06:24 AM Thread Starter
DJ YOHAN's Avatar
I just went out to the car now and swapped the airhoses back as it supposed to be ( according to this picture see attached ) and rear head restraints working now, but the tongue and the handle do not work neither the release from the remote. So this means the pump is not supplying air/vacuum to that air line. Question is why? Could that be because that micro switch is not hooked up and can't signal to pump to operate? I have no idea.
Any suggestions?
Name:	Mercedes s 280 central locking pump.jpg
DJ YOHAN is offline
post #30 of 41 (permalink) Old 12-31-2011, 08:57 AM
syljua's Avatar
Quoted: 41 Post(s)
As a further reference to the connectors on the pump, heres an image of my C140 1998.
It has, like all coupes?, electric lowering and rising of the back headrests, so no double
connector on the white one. (Strange that all 4 central lock lines are connected on a coupe, though...);
br,
syljua
C140 CL500 1998
W123 230E 1984
syljua is offline
    Trunk Close Assist (Soft Close) Zaxxon W140 S-Class 3 04-04-2010 06:45 AM
    Close assist Suzdalov W140 S-Class 20 11-21-2008 02:28 AM
    Close assist Suzdalov General Mercedes-Benz 3 06-08-2005 02:29 PM
    Close assist posix W140 S-Class 29 03-21-2005 02:24 PM
    Close assist system misinformation corrected. At least as it pertains to my car. Brett San Diego W140 S-Class 1 06-10-2004 06:59 AM
