Camshaft timing adjuster wire - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 10-07-2011, 04:20 AM Thread Starter
nhzruthless818's Avatar
Date registered: Jun 2008
Vehicle: 1997 S500V
Quoted: 60 Post(s)
hello everyone. my camshaft timing adjuster was leaking badly and replaced the seals but the wire adapter that connects to it deteriorated and i need some help. i need to know which wire goes where. if anyone has pics of there it would be perfect. and i forgot to mention it is the passenger side. if someone can say which wire goes on top and which on the bottom i bought the plastic adapter but i don't know which wire goes where
nhzruthless818 is offline
post #2 of 7 (permalink) Old 10-07-2011, 04:27 AM
eric242340's Avatar
Quoted: 311 Post(s)
Check out the colour coding of the wires on the drivers side.
ERIC.
eric242340 is offline
post #3 of 7 (permalink) Old 10-07-2011, 07:36 AM Thread Starter
Vehicle: 1997 S500V
Quoted: 60 Post(s)
driver's side has different colors
post #4 of 7 (permalink) Old 10-07-2011, 07:48 AM
eric242340's Avatar
Quoted: 311 Post(s)
OK right, connect them any way you want to start with, its a 50 50 chance you will get it right or wrong, if wrong it will pop the fuse on the gm module located in the module box, you know the coffin shaped box, if you get it right then no probs, either way you only risk a fuse. The GM module has four fuses on top of it I seem to remember and if wrong one will pop and the engine will not start.
ERIC.
post #5 of 7 (permalink) Old 10-07-2011, 10:33 AM Thread Starter
Vehicle: 1997 S500V
Quoted: 60 Post(s)
if the fuse was to pop would i notice? because i connected the wires and i don't have a check engine and car seems to be fine
post #6 of 7 (permalink) Old 10-07-2011, 02:46 PM
eddie a's Avatar
Date registered: Jul 2008
Vehicle: 84 500 SEL ...94 S420..... 95 S500.... 96 S500 95 S600
Quoted: 25 Post(s)
Did you figure it out?
eddie a is offline
post #7 of 7 (permalink) Old 10-07-2011, 10:24 PM Thread Starter
Vehicle: 1997 S500V
Quoted: 60 Post(s)
i guess i did. no check engine light and no misfires or slow starts. so i am guessing its right
camshaft adjuster cgqsm BenzWorld Help 2 09-28-2010 11:58 PM
'07 C280 - Oil leak around Camshaft adjuster and Camshaft Position sensor pcy W203 C-Class 0 07-12-2010 07:40 AM
Camshaft adjuster leaks masterdog R170 SLK-Class 4 08-05-2007 10:23 PM
Camshaft Adjuster Magnet SLTriage R129 SL-Class 3 06-28-2007 11:30 AM
Anyone had to have camshaft adjuster replaced? HopsanGirl R170 SLK-Class 7 12-08-2005 01:53 AM
